Crucial's site says lower is faster . . . but of course there are other relevant factors.
My question: in comparable Ram options that you could install, would a CL rating of 4
really make that much of a difference, vs. a CL of 5 or 6 ?
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
not much difference
running at the same bandwith, a lower cas latency is faster
the difference varies by application, but the difference is about 0-2% overall between cas4 vs cas5. If you visit some of the tech sites like anandtech, xbit, xtremesystems forums a few others, numerous comparison studies have been done
some applications run faster with higher bandwidth, some lower latency it depends on the bottleneck; again it's application specific. Usually when you do your memory settings, there is a trade-off between bandwith and latency (i.e. either high bandwidth or tighter latency settings). Most applications in Windows are not memory bandwidth starved, so using a lower latency is usually the better choice. This includes most games, video apps, general office programs.
also some motherboards may limit the memory settings that you are able to run at, to unlock the best performance, you need a good bios and a good mobo -
Thanks for the info. I have two sets of Ram that I could plug in, both from Crucial (their basic line, not the Ballistix or the one with the heat spreaders and LEDs), both bought at a good sale price. One is a 2Gb. kit, 5300 / 667, with the lower CL figure. The other is a 4Gb. kit, 6400 / 800, with the higher CL figure. Either would meet the MB specs, as is. (Whatever overclocking may be possible, I'm not really interested in doing that.) I'm leaning towards going with the 4Gb kit, even though Windows may only recognize 3.5 of that. I've seen differing reports about that regarding XP, which is what will be running on the box in question.Originally Posted by poisondeathrayLooking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
A 32 bit OS will use about 3.7GB or thereabouts. Some may be used by the video card. If your motherboard can run 6400/800, that would probably be the better choice. Faster RAM usually has a higher CL, but should preform better.
H.264 Converter Comparison
By Joynr in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 02:11 -
comparison between bluray and brrip
By xenotox in forum Blu-ray RippingReplies: 13Last Post: 24th May 2009, 16:17 -
Media type comparison.....
By sungator in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Mar 2009, 20:32 -
Comparison Chart of Over 40 HD Cameras
By Gary Roberts in forum DVB / IPTVReplies: 0Last Post: 17th Dec 2008, 10:32 -
vcr's in a chain to see the comparison
By victoriabears in forum Newbie / General discussionsReplies: 7Last Post: 30th Jun 2008, 19:10
![Computer details: [This list is SELDOM up-to-date !]
Shuttle SX48P2, Q9550, 4Gb.
ATI Radeon 45__ (?)
Win-7 Ent. x86
WD Black 500Gb. + 1Tb.
Shuttle SP35P2 Pro,
Intel Xeon 3230, 8Gb.
ATI FireGL V3400
Win-7 Ultimate x64
Shuttle SH67H3 (i5)
w/ 16 GB. RAM &
Win-10 Pro
SSD + HDD
LG Blu-Ray burner
[acquired used as an already-HTPC,
though not yet assigned to that task]
Shuttle SH67H3 (i7)
w/ similar config to the one above
and others
[also (reluctantly) perform some "IT-by-default"
services for an office, with other computers
there . . . ]
Various older model Lenovo laptops, like T-40
series, T-60
IPAD Pro (Gen. 2)
Video Gear includes:
Oppo 95-BR
Pioneer 520, 640, 460
Toshiba 32HL67
Panasonic G-25 plasma
Pan V-series 58 plasma.
TBC-1000 & other assorted gizmos
Panasonic 4820-SVHS
& various other VCRs
Various Betamax gear
Var. video streaming boxes Comp](/images/buttons/computer.gif)
