When I play the audio on the camcorder or on the TV via composite cables, audio and video are fine. When I try and capture it using the Dazzle 100, the audio is high pitched and chipmunk-like.
I used Pinnacle Studio 12, Instant DVD writer and VLC MP but the audio is high pitched in all of them.
The Dazzle 100 captured VHS tapes perfectly.
Am I missing something very basic?
Results 1 to 19 of 19
don't use any anolog to digital converter. "capturing" miniDV requires the tape be transferred to the computer over firewire. use winDV (free) put the cam in play mode, set windv to create type II avis (unless you have some specific need for type I) and press capture.
http://www.kiva.org/about -
The tapes have been recorded in 12 bit.....but I cant find anything on the transfer software that will let me check the bitrate.
I tried transferring over with IEEE-1394..........but when I play it, the audio is still the same: chipmunkish.
I tried transferring with WinDV and Studio 12....in PAL and NTSC, in DV and MPEG............but there is no change with the audio. -
Is this a problem with one tape or with all tapes?Originally Posted by fsa3011
Does it sound ok at the camcorder analog (red/white) output? If not it could mean a camcorder malfunction.Recommends: Kiva.org - Loans that change lives.
It happens with all the tapes. When I play them on the camcorder, or use the composites to plug them to the TV, everything is fine.......
It would be rare to have DV video ok but audio not. Could the issue be with your computer player?Originally Posted by fsa3011Recommends: Kiva.org - Loans that change lives.
You said your tapes were recorded with 12-bit (4-channel) audio? My guess: the Pinnacle DV preset may be set for 16-bit stereo. (I don't know how presets are selected or changed in Pinnacle, as I don't use that piece of crapware. You'll have to figure that one out.)
I'm running out of ideas. I've never had this audio issue.
Post a gspot capture of one of the problematic AVI files. I too am interested in seeing the audio sampling rate.
Here's audio captured at 16Khz audio sampling rate
test_16k.wav
Copied and pasted into an empty WAV, set to 48Khz audio sampling rate
test_48k.mp3
I'm guessing Dazzle is capturing at a lower sampling rate (weird since it should just be a digital transfer), then your apps are playing back at a "normal" sampling rate, creating the chipmunk effect. I could be wrong (and have been, many many times)
See this:
"The DV format allows for 2-channel 16-bit audio (PCM 48KHz) or 4-channel 12-bit audio (PCM 32KHz). I am not aware of any 16-bit 4-channel cameras." -
I think Dazzle isn't sophisticated enough to know how to handle your 4 Channel 12 Bit audio. It's assuming the audio is 48KHz (which would probably be the case with 90% of the consumer grade camcorders out there) It isn't resampling properly (or at all). The question becomes "How does one fix it?". I've never used Dazzle before, so I have no idea.
Only thing I can think of is to capture via Firewire and WinAvi, then convert your DV avi file to DVD via some Mpeg2 converter program (ConvertXtoDVD, Favc, etc) -
That isn't DV format. That is MPeg2.
I'll bet Dazzle is encoding on the fly as it captures. It just doesn't know that the audio is 32KHzOriginally Posted by edDV
Is your GSpot depicting the raw capture or the video after processed through Pinnacle? Like the others said, that ain't minidv, which should be a DV-AVI format. Make sure you capture through firewire and use software like WinDV to insure your files stay in the DV-AVI realm.
I have never recorded DV audio in 12bit, so I would not know the best method to convert to 16bit -- but I think a VirtualDub audio conversion would do the trick. -
I used Studio 12 to transfer the first one...it must have encoded it too. The one attached below was done with WinDV, and this time, no chipmunks!
This is really strange as I did use WinDV before when 'minidv2dvd' suggested it and the sound was distorted then...
Hope it doesnt revert back to a rodent!
I recommend you use WinDV but with Studio 12 they give you a capture menu and DV format is one of the choices.
Do not capture that DV cam to anything but DV format. It was Studio 12 that was causing the problem.
Also: Switch the camcorder to 16bit 48KHz stereo audio. Your sound quality will improve for future recordings.Recommends: Kiva.org - Loans that change lives.
AVStoDVD Making Chipmunk High Speed Audio
By theWallflower in forum AudioReplies: 9Last Post: 6th Sep 2012, 15:14 -
Capturing footage from Mini DV.
By andreys in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 3rd May 2010, 07:54 -
Problem capturing mini dv audio w/ camcorder other than one used to record
By Nuzy in forum Capturing and VCRReplies: 18Last Post: 22nd Feb 2010, 06:35 -
chipmunk audio
By jekkherg in forum Newbie / General discussionsReplies: 7Last Post: 26th Sep 2009, 23:37 -
Chipmunk-sound-like problem...
By aruwin in forum Video ConversionReplies: 3Last Post: 28th Nov 2007, 04:34
