Hi,
How can I fix the AR of a movie?
Right now, I have two options:
1# Can temporary force MPC to change it.
2# Can load it into Vdub, apply a filter and re-encode it.
Both options are obviously completely unacceptable. There got to be a quick and easy way to fix this without any quality lose right?
The file is WMV3 codec. Its a shame gspot only shows you the data and does not let you override it...
You can try the wmvarchanger for wmv type files
It's originally from DVB Portal website, but the link seems down ATM...
wmvarchanger-1.0.0.zip -
I already tried that tool... could not detect the AR, and when I went to apply a new one it did nothing.
unfortunately wmv is a propietary closed format; not much support for it
You can easily change the container signalling with other formats (e.g. .mp4, .mkv, even .avi), but none of them support .wmv because of it's proprietary nature -
edit dvd without losing quality
By robroth in forum EditingReplies: 8Last Post: 13th Jan 2011, 13:12 -
Shrink DVDs without losing much quality
By ssusca in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2011, 12:57 -
Losing all the quality converting 720p
By TheDizzle in forum MacReplies: 1Last Post: 25th Jan 2009, 12:30 -
Am i losing quality?
By chronic777 in forum Newbie / General discussionsReplies: 9Last Post: 26th Aug 2008, 05:57 -
Am I losing image quality when I do this?
By Ronny G in forum Authoring (DVD)Replies: 3Last Post: 26th Feb 2008, 10:22
