Hi all,
I have some MKV files, they play in media player just fine but i want to watch these on my tv with my samsung blu ray player, how do i do that?
If they are blu-ray compliant use tsmuxer and remux to a blu-ray/avchd format. Burn with imgburn. See https://www.videohelp.com/guides?formatconversionselect=MKV%20to%20Blu-ray .You can also try multiAVCHD .
If the mkv is not blu-ray compliant reconvert to blu-ray video using ripbot264.
If you don't know if the mkv is blu-ray compliant then post the details about the mkv, use mediainfo, open mkv, View->Text and post the result here. -
Thanks guy's
Does using windows 200 cause any problems? I only have a amd 3100+ with 512mg ram and only a dvd burner -
Windows 2000? It usually works about the same as XP, though drivers may be a bit harder to find. You will probably have to try the programs mentioned and see how they work.
Not mentioned previously, but the DVD disc manufacturer may also cause playback problems, along with the BD player itself. Not all DVD discs are compatible with all players or burners. If your burned disc is BD compatible, then the disc or the player is in question. Usually recommended are Verbatim or some Sony discs, or Taiyo Yuden, though they are normally mail order. -
OK
Thanks to all.
I think it could be time to upgrade my computer also
How convert MKV file with different mkv LEVEL (5.1 to 4.0..)
By Nabucanezor in forum Video ConversionReplies: 19Last Post: 8th Nov 2013, 17:56 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 11:50 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 02:17 -
Converting MKV to a smaller MKV file
By Boriskali in forum Video ConversionReplies: 3Last Post: 1st Dec 2007, 07:07
