I've been having this trouble for quite some time now, I've uploaded a few videos on YouTube and some of those appeared desynchronised with the sound (see here: http://uk.youtube.com/watch?v=QL43i0WWQeM ) while the uploaded video from my machine plays very well (tried with VLC and WMP). Here are some details about it:
General
File size : 133 MiB
Duration : 10mn 50s
Overall bit rate : 1 719 Kbps
Writing library : VirtualDub build 30091/release
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 10mn 50s
Bit rate : 1 579 Kbps
Width : 480 pixels
Height : 384 pixels
Display aspect ratio : 5/4
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.286
Stream size : 123 MiB (92%)
Writing library : Lavc52.0.0
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 10mn 50s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Video delay : 7ms
Stream size : 9.93 MiB (7%)
Alignment : Split accross interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Nevermind, fixed it by re-compressing the audio, and loosing some little quality this way ...
Youtube video looks different between my website and youtube.com
By jumpymonkey9 in forum Video Streaming DownloadingReplies: 0Last Post: 14th Oct 2011, 10:53 -
Is this the highest possible quality for YouTube? YouTube compresses video?
By chrissyelle in forum Newbie / General discussionsReplies: 17Last Post: 5th Oct 2010, 12:33 -
Recommended upload video format for maximum sound quality on youtube
By waigy in forum Video Streaming DownloadingReplies: 25Last Post: 12th Sep 2010, 18:09 -
Uploading a video to Youtube that will fill the ENTIRE youtube player.
By Clifurd in forum Video ConversionReplies: 16Last Post: 12th Mar 2010, 14:40 -
Why won't YouTube convert a video that was downloaded from YouTube?
By brassplyer in forum Video Streaming DownloadingReplies: 0Last Post: 5th Dec 2008, 05:47
