A few questions please...
1.Thinking of upgrading and wondering how it will do...
Also this spyware stuff on XP how easy to bypass...
Have they cracked XP yet??(Im not asking for a crack, just wondering..)
2.Also, I'm building a new Athlon 1.4ghz/128DDRRAM...can anyone tell me about how long it should take to encode a 2hr movie in normal quality?
Currently im at 14hrs on my 533k6-2
Results 1 to 10 of 10
I have home xp on my new hp pavillion. It takes me about an hour and 15 minutes to encode 70 minutes. And the burn of that takes about 5 minutes with vcdeasy. In case you don't know, I had to get an aspi layer because I was told xp does not have it. I use all the programs you mentioned and it works well.
Hello,
I'm using a P -4 1.7 g and have 512 mg mem and this is a XP machine. The only thing I had to do was upgrade my ASPI layer. It takes me 4 to 5 hours to encode average movie. If your planning on going XP get more memory, alot more memory. My option is go Win 2000 Prof. of if you have to go XP, get the Prof. ver.
Terabyt1 -
I am using that setup and encoding takes less than real time. I have an AMD 1.47 and 512 DDR. It should take you at or less than real time if you are doing the DDR RAM. I used forceASPI on my system. I was still able to rip before using it and haven't tried to rip since. My rip speed varied from 3.5X to around 6.8X before forceASPI. I have other problems though. I can't encode non-standard sizes, which is a post of mine somewhere else. The short version is that I am forced to use 480x480 or 720x480 for MPEG-2, I can't go down to 352x240 and make nonstandard. When I do I get no picture.
I have been running XP on my AMD 1600+xp machine for a couple months now, outside of a few hardware glitches with winxp all has been great, never had a single lockup running any video software and I have ran just about everything. I have 512mb ddr ram and it takes about 2 hours to encode a 1.5 hour movie in 4:3, if it is 16:9 it takes about 1:50 to do it.
you guys R 4gettting 2 mention the type of encode, VCD or SVCD...
352x480 or 480x480 or 720x480, etc.
as each of these will vary your
encoding time.
for me, my last 1 hour capture took less then 3 hours to encode to an
xSVCD. These are my specs for this "time" on my old PC setup:
* Athlon T-Brd 900MHz w/ PC133 128mb ram
* ATI-TV Wonder capture card
* Virtualdub frameserved to TMPG
* xSVCD(352x480/CQ_VBR1850/2500)
On my current system, I'd don't have any real specs for a 1 hour
capture and encode "time". Sorry!
But, about the only difference is my CPU chip. I went from a (above)
to an "XP 1700+" and I could sware
that my encoding times have NOT
changed!!, based on NO change in my process.
-vhelp -
Afternoon all.
Again, we all (you all) need to be more open with your encoding times!
When you post your encoding times here, it's a bit missleading for
some of us, cause you leave out any filtering and at what resolution for your encoding that may be the cause of your long encoding times.
So, when someone says, 12 hours, then U need to mention if you use:
* "filters", and which ones, level settings...
* what "resolutions"
Otheriwise it's not a true or fair assessment of encoding times for us post readers. ie, 1.4ghz takes 12 hours, while another 1.4ghz takes 2 hours. So, as you can see below, ...are my complete specs for an encoding project.
My last 1 hour capture took less then 3 hours to encode to an
xSVCD. These are my specs for this "time" on my OLD PC setup:
* Athlon T-Brd 900MHz w/ PC133 128mb RAM
--> capture: 352x480
* VIRTUALdub frameserved to TMPG
* xSVCD (352x480 / CQ_VBR.70.1850.2500) (MPEG-2)
* Filters(VD) = Sharpen 3
* Filters(TMPG) = NONE
* ENCODING time: < 3 hours
jonnabj, based on your 1.4ghz cpu, I would say that U used a few
filters in your enocodes, hense the 12 hour encoding time.
Maybe we all shoudl use this format when we post specs and things.
It would clear up any doubts or confusions/assumtions left in our
minds!
-vhelp -
I've got :
A P4 1700
1024 MEG RAM
16 X DVD ROM
24 X BURNER
On an average 100 min movie rip :
Smart ripper takes between 8 to 10 minutes to rip the DVD
DVD2AVI takes around 12 minutes to do its stuff ! ( Project Save )
And TMPGenc ( VCD Encode ) takes 2Hours 20 Mins.....
Hope this has helped.
Paul. -
Oh.... And I forgot to mention.... Im running XP Pro......
and I also have to drop the 'winaspi32.dll' drivers into Windows\Sytem32
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
TmpGenc Authoring Work Shop 4
By pepegot1 in forum Authoring (DVD)Replies: 0Last Post: 1st Apr 2010, 18:43 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
Does TMPGenc Plus 2.5 work on Vista Ok?
By leegutcher in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2007, 07:22
