Hello,
I have a JVC camcorder GR-D60E http://www.dooyoo.co.uk/digital-camcorder/jvc-gr-d-60e/
I don't use this anymore since i bought a new camcorder, but i still have a lot of dv tapes
i need to transfer to dvd.
I hooked it up to my computer (Dell Inspiron 530) with Windows Vista Home editon Service pack 1.
I used the usb connection and Pinnacle 9 for the transfer.
Now, Vista recognises the camera and Pinnacle transfers the videos.
But in the preview window the picture is of a very bad quality, like a webcam.
The resolution is terrible. I saved a small clip using the best settings,
but when i play back the clip it's still like i'm watching a webcam.
Could it be that i'm using the usb connection instead of a firewire card ? Which i don't
have. If this is the case, what kind of firewire card can you recommend ?
Or is it some other problem ?
Thanks for your time.
Maarten
Thanks ! Well, never had any problems with Pinnacle before. Is it of any importance which firewire card i need ?
firewire 400 1394a is fine, just make sure the card will work with whatever your computer has for open motherboard slots. pci, pci-e ?
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 18:35 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 13:42 -
Pioneer DVR-560HX & random problems with CAM module + video adjust menu
By vincent_scot in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Mar 2009, 11:03 -
Edit 3 cam's with Pinnacle Studio 12 Yes you can
By Habby in forum Authoring (DVD)Replies: 2Last Post: 26th Jan 2009, 19:28 -
Can't download from my jvc DV cam to my notebook
By dmark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 31st Jan 2008, 15:29
