I am attempting to convert my library of DVDs into a back up format using a MacBook Pro with one of the new Matshita UJ-867 drives.
Two of my friend's have the same computer but older with different drives and can use either Visual Hub/Mac the Ripper/Handbrake.
However, when I attempt to use any of these to rip and convert the file or if I even try to watch a different region DVD using VLC the image comes out a total pixelated mess.
The converted file does the same.
It only seems to work with the region the drive is originally set to. You can change the drive region five times on a Mac but even when I have changed the region it will not convert the files without digital interference all over the place.
Do I have to flash the drive firmware? Or just give up?
Thanks for your help.
Results 1 to 1 of 1
DVD encode settings help pretty please
By supportpartners in forum ffmpegX general discussionReplies: 6Last Post: 11th Nov 2011, 05:42 -
Converting VHS tapes to DVD, in particular the macrovision issue
By Taildraggin in forum Video ConversionReplies: 1Last Post: 26th Jul 2011, 07:40 -
Audio/video/subtitle sync problem converting MKV to DVD (Muxman issue?)
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 7th May 2010, 12:23 -
Not free but pretty good converter for MKV to other formats, including DVD
By moviebuff2 in forum Video ConversionReplies: 0Last Post: 27th Dec 2007, 08:04 -
A pretty good DVD library manager
By NeilH in forum Newbie / General discussionsReplies: 0Last Post: 8th Oct 2007, 15:23
