What's the best format DivX or Xvid I can get?
Would this for example be an avi file that has 720p in its name?
I've seen these and have in the past downloaded
But I haven't been able to get these to play on my normal Divx player
OM
The files you have are high definition and will not play on many dvd player with divx support. You will need to find a player that supports high defintion play back. There are terms for the various profiles but I cant find them.
some options
Buy new dvd player
Computer playback (can connect computer to television)
reencode (AVIrecomp is made for this purpose) -
thanks for the reply
i've just bought a new tv + bluray player
therefore i want this highest quality
so i should just watch out for 720p files?
is it possible to get avi rips that are 1080p?
thanks -
1080p yes they exist but may not be in divix or xvid. Possibly x264/H.264.
I don't know about best quality resolution is not the only factor. -
And your blu-ray player may not play them. Just because it plays Blu-ray discs at 1920x1080 doesn't mean it can play Divx/Xvid at that resolution.
Also even though blu-ray supports H.264 they may need to be authored or encoded with specific settings.
Many folks were able to get these Blu-Ray rips on standard DVDs playable in their Blu-Ray players.. It was known as BD-5 and 9. But it seems that Sony wasn't too thrilled with this and the latest firmwares have made this much, much tougher. But as is usually the case where there is a will, there will be a way.
The AVS forum is a good place to follow such discussions.
http://www.avsforum.com/
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Best format for Xvid/Divx files on DVD
By schematic2 in forum Authoring (DVD)Replies: 3Last Post: 12th Oct 2010, 13:51 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 19:16 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
