I got an old analogue camcorder (Sony video 8) would like to transfer to my WinXP pc.
I can capture the file as AVI:
The size is huge, for a 20 minutes video -
720x480 takes up 1.9 GB
720x576 takes up 2.3 GB
However, for .MPG file:
Same footage, it takes 300 MB.
I noticed the resolution of MPG is much lower, something like 300x255.
The purpose I want is simple:
First to keep a best possible resolution footage to keep as record.
Second may burn to DVD (Blu Ray later may be).
What format should I capture? AVI or MPG?
You didn't specify a capture device. I'll assume a TV tuner.Originally Posted by ManUtdFans
1. Classic approach:
-Analog capture to 720x576 or 768x576 Huffyuv (lossless compression).
-Then edit Virtualdub
-Then encode to MPeg2 ~6-8 Mb/s for DVD
-Then author the DVD
2. Above but attempt real time software encode during capture ... results in heavy quality hit.
3. Real time hardware MPeg2 encoder (e.g. Hauppauge PVR series)
4. Real time hardware DV format encoding (DV camcorder pass-through or Canopus ADVC)
5. Capture to standalone DVD Recorder (hardware encoding) at 1hr rate.
6. Other.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Hi,
I am using the external USB capture device called "EasyCAP Video Adapter with Audio".
So I am using the RCA connection.
I have heard about the size of video file is not that big as I got for AVI files:
They said 1 GB per hour.
Which format is better quality:
AVI or MPG ? -
There is a long discussion about that device here. Best to ask them.
https://forum.videohelp.com/topic331168.html?highlight=easycapRecommends: Kiva.org - Loans that change lives.
Analogue to Digital capture software
By ManUtdFans in forum Capturing and VCRReplies: 9Last Post: 16th Jun 2011, 12:10 -
Convert analogue camcorder tape to pc
By ManUtdFans in forum Capturing and VCRReplies: 9Last Post: 29th May 2011, 22:59 -
analogue video from VHS tapes to PC
By teka1 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 10:32 -
Analogue Capture problems
By Lensmeister in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2009, 06:20 -
Analogue Capture
By Sonnyt in forum Capturing and VCRReplies: 3Last Post: 26th Mar 2008, 20:49
