I have MMC 7.5. I can hear sound if just playing TV. However, whenever I try to record I get no sound. I have no idea what the problem is. I'm using Win2k. I check that input is selected with volume control (recording). Please help.
What kind of sound card?
Need to make sure line in is selected to record an not muted. -
I'm using a Aureal Vortex 2 (diamond version). Line in is selected and not muted. Thanks
I too have the same problem with my AverTV card, my soundcard is an SB Live!. Any help from the experts would be appreciated.
Try opening the audio volume control, and view the recording properties (Options->Properties->Recording), you can then view/change the input that is currently being used for capture.
I uninstalled and reinstalled the software. It was the only thing I hadn't tried and it worked (just made sure to do a thorough uninstall). Thanks everyone
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 06:02 -
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 20:56 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 14:52 -
Visiontek ATI Radeon HD2400 Pro Help
By mattman1968 in forum ComputerReplies: 2Last Post: 11th Jan 2008, 12:13 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 15:25
