Hi all!
I'm quite new to all this video editing stuff, but i am trying to learn it, cause i need to put a snowboard movie together.
- then i was wondering.. What do i do when i want some seconds in a clip to be either slowmotion or speed it up?
I use Adobe Premiere Elements 7.
Cheers!
FredA
The only powder that gets me high, is the powder from the sky
I don't use Premiere Elements but I do use Premiere, have for years. It should be similar. Basically, you can right click on the clip and choose speed/duration and adjust it to what you want.
There is a great tutorial that explains time remapping (slow, fast and reverse motion.)
http://www.adobe.com/designcenter/video_workshop/?id=vid0235
Brainiac -
Thank you both very much, will try it out later!
EDIT:
The link doesn't seem to work?
2nd EDIT:
Were you linking for this? - http://help.adobe.com/en_US/PremiereElements/7.0/WS09e4b3c48f3a79fc19b622510385d4355c-...385d4355c-7f2a
Is that the easiest way to do it?The only powder that gets me high, is the powder from the sky -
I clicked on the link and it works for me.
The tutorial shows how to use time remapping to slow down, speed up, and reverse a clip.
Brainiac -
Oh, it worked in IE. Thanks
will try to see if i can figure it out in Elements 7, it doesn't look completely the same as on the video.
Sony Vegas, How do you change the clip length of multiple clips? Please hel
By Purplehayes in forum EditingReplies: 11Last Post: 30th Dec 2014, 06:19 -
Is there a way to change JUST the audio on a video clip?
By jbitakis in forum AudioReplies: 6Last Post: 12th Dec 2011, 17:00 -
Sony Vegas: Any way to undo clip speed adjustment?
By duderdude2 in forum EditingReplies: 2Last Post: 15th Feb 2010, 22:03 -
adobe premiere 6.0 problem clip speeding up why?
By suomiaussie in forum EditingReplies: 5Last Post: 20th May 2008, 22:02 -
How edit a clip to play @ 1/2 speed (slow motion) in Vegas 8 plt.
By Jensen in forum EditingReplies: 7Last Post: 12th Feb 2008, 13:23
