Hello friends,
I am not very familiar with the ffmpeg options, but apparently something wrong goes on, because when I convert to xvid by ffmpeg (WinFF frontend) the result misbehaves on my standalone player (RJ-1000).
Precisely - after playing for example the first 20 seconds it freezes the picture, while the sound goes on... then after another maybe 15-20 seconds the video will start playing OK (yes synchronized with the audio, which simply means that you skip parts of the video). Then after a while - the picture freezes again.
If I encode by using Virtualdub this problem never happens.
The problem is - I cannot always use Vdub, for example if the input is a .flv file.
Here is an example of the settings coming from WinFF:
"C:\Program Files\film_utils\WinFF\ffmpeg.exe" -threads 2 -i "C:\aaa\steven_jobs.flv" -r 30 -vcodec libxvid -vtag XVID -s 720x400 -aspect 16:9 -maxrate 1800k -b 800kb -qmin 3 -qmax 5 -bufsize 4096 -mbd 2 -bf 2 -flags +4mv -trellis -aic -cmp 2 -subcmp 2 -g 300 -acodec libmp3lame -ar 48000 -ab 128k -ac 2 "c:\aaa\\steven_jobs.avi"
pause
Any advice is very welcome !
Thank you!
Best wishes,
UP -
use latest Virtualdub with flv plugin-it can load flvs
with other plugins, it can load wmvs, mpeg2 and mov. also has directshow plugin which lets you load practically everything
Linx to plugins(except directshow) are on the videohelp page for virtualdub. -
try with this
"C:\Program Files\film_utils\WinFF\ffmpeg.exe" -threads 2 -i "C:\aaa\steven_jobs.flv" -r 30 -vcodec libxvid -vtag XVID -s 720x400 -aspect 16:9 -maxrate 1800k -b 800kb -qmin 2 -qmax 5 -bf 1 -flags +4mv -trellis -aic -g 150 -acodec libmp3lame -ar 48000 -ab 128k -ac 2 "c:\aaa\\steven_jobs.avi"
shorter gop, less b frames, less qpmin
BHHHDConvertToX, AutoMen, AutoMKV Developer -
Including the .lnk shortcut files themselves.Originally Posted by mgh
Missing options in FFMPEG ? ex: cartoon for libxvid .. Please help!
By hugzzz in forum Video ConversionReplies: 1Last Post: 23rd Feb 2012, 13:10 -
Used Deshaker on a footage, but bad result. Please help.
By namphong0612 in forum EditingReplies: 12Last Post: 11th Jan 2012, 23:13 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 06:09 -
FFMPEG Stream mapping options result in conversion failure
By JackJack in forum Video ConversionReplies: 6Last Post: 28th Jun 2008, 00:19 -
ffmpeg options for PS3 transcoding
By techid in forum LinuxReplies: 6Last Post: 23rd Jun 2007, 04:40
