Hello, I converted a HD MKV file to a PAL Mpeg II file using TempEng Xpress 4.4. The problem is the subtitles did not transfer over? Is there a way to do this.
Please note I can only convert to Mpeg 1 or 2 files. I have relatives in India whose Sony DVD player cannot accept any other format.
mpeg by its self cannot contain subtitles you will need to author a dvd
Ok, so I chose to make a DVD, will it give me an option to trasfer the subtitle file?
I don't know much about mkv or the program you are using. The transfer depends on how the subtitle is stored. If it is stored as text many authoring programs will accept it and place it with the video. If it is stored as a set of images I know nothing about inserting them. Does the program you are using have a dvd output option you could try that? Otherwise or if that didn't work, you will need to extract the subtitles and place them in the authoring program.
However the best option is to just try it with your program or read the documentation. -
If you use mkvextractgui, you can extract the specific subtitle (e.g. it might be idx/sub, .srt , .ssa or some other format of subtitle)
You can use a free DVD authoring program like FAVC that will accept some subtitle formats. I don't use TMPEGEnc products very often so I don't know if that will work. Another easy to use program that works well is convertxtodvd, but it costs $
There might be issues if that DVD player in India is PAL vs. NTSC , or it might play both, you would have to check with your relatives.
MKV File will not Transfer to Other Drives
By Wanderlustus in forum Video ConversionReplies: 3Last Post: 15th Apr 2012, 23:07 -
Converted mkv file can't keep DTS audio
By thegrube in forum Video ConversionReplies: 4Last Post: 11th May 2009, 15:49 -
avter converted mkv to mp4 the file is 1.53 Gig
By d2idan in forum Video ConversionReplies: 26Last Post: 1st Jul 2008, 05:38 -
again after converted mkv to mp4 the file is now 2.91 Gig
By d2idan in forum Video ConversionReplies: 1Last Post: 24th Jun 2008, 09:12 -
alltoMKV converted MKV file sound out of sync.
By necrobutcher in forum Video ConversionReplies: 1Last Post: 10th Jun 2008, 18:25
