Hi i am wondering how can i do the following.
i have a canon xl1 camera . my dv port for the firewire on the camera is broken meaning i cant' use firewire cables to connect my camera to the pc . i am looking for a cable or box or anything that i can connect my camera to my pc so i can capture my videos on sony vegas and also use my camera for live streaming on ustream. is there suck cable that i can have video and audio ? i seen RCA TO USB adaptors can i acomplist this with one of those ? is there someone or a place where they fix my dv port on the camera . i tryed canon they dont work on those camera no more since they are discontinued and i tryed a local store around ny and they told me to chekc with canon. any help is very appreciated .
Results 1 to 16 of 16
DJSPYDER, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome to our forums.
Originally Posted by DJSPYDER
Bad News:
Repair will be expensive but maybe in NYC someone is doing a higher end camcorder salvage buiness and can swap modules but camcorder disassembly is difficult. A burned IEEE-1394 port will be their top request so will be top price. Compare repair cost to used functioning model. Also the XL-1 may have head hour meters typical for upper range cams..
Good news is webcam capture is adeqate from the S-Video port. S-Video from a high end model is much better than consumer level.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You can transfer tapes you've shot on it using the "corder" part of any MiniDV camcorder. Buy the cheapest you can find to use as a tape drive. That doesn't help you for streaming, but will transfer tapes with no loss of quality. Probably much cheaper than fixing an XL1.
Steve -
Thank you guys so much for the replys and sorry for the topic name . so from what you guys are telling me there is no work around gettin audio and video to stream from the camera . i kno i can use s video buy i would also get audio at the same time. i seen some RCA To Usb Cables i was wondering if that would work .but looking at the camera i dont see a audio out rca so am thinking it would be also the same thing as using an s video cable. all i want to do is stream on ustream with the camera and get some audio too .
You can still do analog capture (as edDV mentions re S-video). There are plenty of analog capture devices that connect via USB. Many can capture composite video (yellow RCA) or S-video (yellow 4-pin), along with stereo audio (red/white RCA).
Your XL1 is a high-end unit and has all four connections available (no weird proprietary cable to worry about). They are under a flap on the back of the unit (see p56 of the manual).John Miller -
thank you for the reply. do you have any particular one you would recommendo looking at ?
Originally Posted by JohnnyMalaria -
I'll have to defer to someone else to recommend an analog capture device. I suspect budget will be your deciding factor. At some point, they may cost more than a used DV camcorder.
Since your source is digital, you'll find capturing via S-video is pretty decent. People tend to poo-poo it because it is usually associated with consumer analog recording formats that show their weaknesses compared to digital.John Miller -
well since i just wanna stream audio & video live on ustream i was looking into these products.
capturing is not a big deal for me since i can get another camera just to capture tapes.
so will any of these products in this link will do the trick ?
http://www.tigerdirect.com/applications/category/category_slc.asp?Recs=10&Nav=|c:1428|&Sort=4
my budget limit would be around $100 i would say . but i wanna be sure i will be able to broadcast on ustream or any other site with my camera.
Stream to what? What is your quality expectation?
Why an XL-1?
If you are streaming to the internet, what format, what bit rate?
Why wouldn't a simple tuner card work?
http://www.newegg.com/Product/Product.aspx?Item=N82E16815276002
That is their cheapest one.Recommends: Kiva.org - Loans that change lives.
than x for the reply edDv. to answer you questions . i just wanna stream live video and audio if possible via ustream. i have and xl1 which is all i have and will be using . quality i expect to be much better that what i am used to because i used a webcam so i guess since the quality of the xl1 compared to a web cam its better quality wont be an issue for me. format and bit rate sorry but i have no idea . am sorry i just dont know much about these things that why i wanna keep working with the xl1 until i become more experience and then i can move on to a better camera. but if you think that tuner card will let ustream regconize my camera using Rca or s video then i will buy it i just wanna be sure before i get my hopes up.
Originally Posted by edDV -
I was asking you to define "upstream". Is this just Netflix or Yahoo Messenger? Then the XL-1 will work but is overkill. Use a capture card approved by your application.Originally Posted by DJSPYDERRecommends: Kiva.org - Loans that change lives.
I think you are confused . Its not "upstream" its Ustream.com the website that allows you to broadcast video and audio live.
Any camcorder (S-Video) or webcam (USB) should work.Originally Posted by DJSPYDERRecommends: Kiva.org - Loans that change lives.
HERE IS YOUR BEST AND CHEAPEST SOLUTION!!!!! I had the same thing and with stupidity and impatience I also fried the fire wire port on my HD cam.
Black Magic Design has the best HD video equipment at a consumer price.
I got the "Intensity Pro" for HDMI and Analog HD/SD Editing card $199.00
It does full HD recording right from the camera or from tape, if not for this baby I was gonna throw my cam in the garbage
http://www.blackmagic-design.com/products/
oooooo after searching this link for you I seen more stuff I want......
Cheers!
Sony HC3 firewire port dead,cheap miniDV camcorder to use for transfer?
By alegator in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 76Last Post: 13th Jul 2011, 19:59 -
Howto connect VGA to S-Video port?
By bulava in forum DVD & Blu-ray PlayersReplies: 3Last Post: 8th Jan 2010, 09:12 -
No Ethernet port and wireless adapter but want to connect HS Internet
By coody in forum ComputerReplies: 1Last Post: 11th Dec 2009, 13:57 -
XL1S firewire/DV connection dead what camera to use to get miniDV to comp
By gabbs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Sep 2008, 14:00 -
How to connect VGA port on laptop to Svideo port on tv
By hulk420 in forum ComputerReplies: 4Last Post: 5th Jun 2008, 15:07
