I having an issue burning a Verbatim DVD+R DL disc using Roxio Toast Titanium 10. I am trying to burn a TS file that is 7.77 GB and each time I try using Titanium 10 an error message appears:
Sense Key = ILLEGAL REQUEST
Sense Code = 0x26
INVALID FIELD IN PARAMETER LIST
Has anyone else had trouble with this? I have used Sony DVD+R DL and same issue.
I am using:
Macbook 4.1
Intel Core 2 Duo
2.4 GHz
Firmware Revision BP10
Interconnect ATAPI
PLEASE HELP!!!
Results 1 to 21 of 21
Have you tried saving as a disc image first and then burning the disc image to DVD using the Image File setting in the Copy window?
At what point in the process does the error appear? What setting are you using in Toast (I'm presuming the DVD video setting in the Video window). -
I have tried saving it under image but that did not work either. I have tried burning it x2 and same thing. I have tried resetting my macbook back to 10.5.2 because there was speculation about it not working with the new 10.5.6. I'm not sure it is the media
lawnman, edit? I moved it to the Video TS file and I've also tried the DVD video one as well
Has this drive ever successfully burned a DL disc before? There's always a chance that the drive itself is defective.
Tomlee59, I burned a single layer with no problems at all. What program did you use to burn the dual layer?
you can try LiquidCD (it burns double-layer too)
http://www.maconnect.ch/
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
Originally Posted by mnelson220
thanks!! Doesnt liquidcd compress the file and is not that great of quality if it is compressed?
it wont burn as a dvd once saved as an image, it will only burn as a data but I want it to burn as a regular dvd so that I can play it on my dvd player
RTFM? When I saved it as an image it renamed it .toast. The original file came as a .img file torrent so I mounted it to get the TS files, both audio and video.
Video DVDs are UDF format discs. If you attempt to burn them as anything else (from within Toast), you'll not get anything that will play in a DVD player (but might play fine in your Mac).
Now, if you take a video file and ask Toast to make you a Video DVD, it will do whatever transcoding and authoring are necessary and then...yep, you guessed it...burn you a UDF disc.
Let us know how it goes. -
ok so one file worked using it as an image file (file size 5.95GB) but the other one (7.771 GB) would not, keep getting an error message. But when I mount them the 5.95GB reads as a file but the 7.71GB reads as cd read only. I dont know if this was because I noticed this during the burning of the 5.95GB.
the 5.95 GB image file burned as a DVD but the 7.71GB image file would not burn as a DVD. Both of them do mount and play as a DVD but the 7.71GB image file would not burn as a DVD. I appreciate your patience and help!!!
So the 7.71GB image file fails to burn at all or burns as a data DVD?
i can get it to burn at a data DVD no problem but will not burn as a video DVD
I got it to work!!!! I unchecked the compress to fit check box and it I'm guessing that is what made it work. I am beyond ******* excited!!! I appreciate your help and patience with me rumplestilskin!!!
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
Pioneer DVR-220 and playing dual layer problem
By whitemtntn in forum Newbie / General discussionsReplies: 4Last Post: 7th Jul 2008, 18:12 -
Problem Writing Dual Layer (first time attempting DL)
By brett0973 in forum Authoring (DVD)Replies: 5Last Post: 9th Nov 2007, 21:46
