On my wifes laptop (Vista), AVI files with AC3 audio do not play any audio. I used GSpot and it said the AC3 codec was installed. I also downloaded the 'AC3 filter version 1.51a', and still no audio. All files play fine on my desktop pc (also Vista). Any ideas? She really likes Windows Media Player, and doesn't want to switch to another player.
Thanks!
Go into the ac3 filter config and turn up the master volume. Also try playing files with vlc and bsplayer . what does gspot say when you try to "render" the audio? does it show a fully supported decode path?
Problem solved. When I went to run the Config program, it said it wasn't installed. So I redownloaded & reinstalled the whole AC3 Filter program. Now it works fine!
Thanks again!
Subtitle Edit doesn't play AC3
By allianceserivce in forum SubtitleReplies: 3Last Post: 17th Dec 2011, 12:13 -
Why WMP doesn't play DTS audio (MKV, M2TS files) ?
By mahogany in forum Software PlayingReplies: 2Last Post: 11th Dec 2010, 15:45 -
Vista Media Player 11 doesn't play MP3 Codec Missing
By mlong30 in forum AudioReplies: 6Last Post: 29th Jun 2008, 11:49 -
No Audio Output in AVI file where Codec is Installed
By yoshijam in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2008, 16:32 -
VD Complain Audio Codec Not Installed
By ks47 in forum Newbie / General discussionsReplies: 2Last Post: 19th Oct 2007, 11:46
