I've been trying to take two avi files which play fine in Media Player (the the volume is a little low) and combine them into a single dvd mpg file using TMPGEnc Xpress & DVD Author.
The problem is, neither program will render the dvd (or mpg file on my computer) with sound. The audio is just white noise.
Does anyone have ANY idea why this is happening, and how I can correct it?
Thank you,
Hal
I'm afraid. I'm afraid, Dave. Dave, my mind is going. I can feel it..... Yup. Spppllttt. It's gone.
Run them through Avi_Gain_Soopa_Loud.bat (see link below) . Play the resulting files and see if you get much louder AVIs. If it is louder, feed these resulting files to TmpgencXpress and make sure you turn off any audio effects settings you may have used in your previous encoding attempt.
https://forum.videohelp.com/topic314909.html -
Soopa,
Will this effect the white noise problem? Any idea WHY I have this white noise problem?
Thanks for the assist!
HalI'm afraid. I'm afraid, Dave. Dave, my mind is going. I can feel it..... Yup. Spppllttt. It's gone. -
What codecs are used for these files?
Do you hear the noise also in your standalone?
DTS sound often comes up as noise in PC, because of missing codec.
(but Pegasys Apps donīt make DTS, I guess)
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 03:40 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author & Dolby 5.1 Digital Sound - Can it be Done??????
By Sparehead01 in forum EditingReplies: 2Last Post: 28th Dec 2007, 15:53 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
