    Jan 2009
    I am looking to up grade my system and need suggestion for a new motherboard for an Intel Core 2 Duo E8600 Processor. I am currently running Intel Core 2 Duo e8400 3.0 on a Gigabyte EP45-Extreme with 4gb of ?1333 and a Dark Night Radeon EAH4870 1G. Any suggestion on a motherboard that would run a Intel Core 2 Duo E8600 Processor and the rest of my components would be helpful.
  2. Member Soopafresh's Avatar
    Jan 2004
    We seem to like Gigabyte Motherboards around here. Why not the same motherboard as you currently have ?
    Jan 2009
    The North Bridge will not handle the E8600 Processor on my current motherboard. I was hoping someone might be currently running an E8600 on a motherboard they are happy with and could recommend. This is my first one I had built and first upgrade, trying to learn more as I go. I only know the suggested motherboard that was sold with the E8600, But the reviews on the motherboard were not very good and I don't know enough to about motherboards to get everything I need without having to change other componets.
    Nov 2002
    Intel says the E8600 runs on the P45 chipset and Gigabyte say the Gigabyte EP45-Extreme supports the E8600 CPU.
    http://processormatch.intel.com/COMPDB/SearchResult.aspx?ProcNbr=E8600
    http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2860
    Jan 2009
    Thank you for the help. I looked at the same information
    "Intel says the E8600 runs on the P45 chipset and Gigabyte say the Gigabyte EP45-Extreme supports the E8600 CPU"
    This is why I went ahead and bought the e8600 and had a friend install it. After it was installed we only got the blue screen and went black. we found out the North bridge needed 2 more volts to run the e8600. Could this be right? Or is something else wrong in installing it?
  6. Mod Neophyte redwudz's Avatar
    USA
    I don't think so, that's a typo. The NB would run at 5V max, more likely ~1 - 2 volts, same as the CPU, AFAIK. Some MBs have the capability of manually adjusting the NB voltage by a couple of tenths of a volt.
    Did you update the BIOS before installing the CPU, or at least make sure it's compatible with the CPU?
