The HDMI audio from my TWC box creates some static on my TV Speakers. The analog audio from my cable box is fine. I prefer the HDMI video over component because I am having some interference on HD channels (wavy lines) occasionally that are very annoying. I haven't found a way yet to eliminate them except to go to HDMI.
I have a Mits 62725 DLP TV. How can I make the DVI audio inputs come alive if I use the HDMI cable from the cable box? I don't see a DVI output on the cable box even though it is an option in the settings on the box. Is there a way to trick the TV into alloing DVI analog input?
I've tried turning audo off on the Monlink input (HDMI) in hope that the inputs would start passing audio - but no go.
I appreciate the help.
Originally Posted by hamiltonplRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If your TV allows analog audio input while viewing via HDMI you should be able to force the cable box to output analog audio via the red/white RCA connectors.
I would first try another HDMI cable,if that doesn't help then get another box from your cable company.
I'm not sure about TWC but Comcast allows you to change the audio compression,see if there's a setting for Optimal Sound.
Monitor Inputs - DVI-D vs HDMI
By videobread in forum ComputerReplies: 9Last Post: 17th Apr 2012, 16:41 -
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 08:31 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
DVI-I to HDMI Cable - no picture
By DocDan in forum Newbie / General discussionsReplies: 4Last Post: 28th Sep 2008, 21:45
