i made a video montage of my photos with music and the program i used keeps adding
MY PHOTO COLLECTION
By xxxx
in the first few seconds of the video. (basically a black screen with white lettering of the above)
i cant edit out (cut out) the first few secs coz the music has already started.
so im wondering if i can replace the words "my photo collection..." with a photo of myself or something.
any help greatly appreciated.
If you mean editing the photo program, probably not easy or practical. But you could look in the program folder to see if there is a file that creates the title page. Easier would be to create your own title page and paste it to the beginning of your video. I would add a blank audio track also or you might end up with audio sync problems.
i dont really want a title page.
id prefer to cover up the "my photo collection...by..." wording with a photo.
but im not very sure how to go about it. -
1: Gspot > video scale + fps + video bitrate (remember these)
2: Then you need to slice this part from you file, split clip into two pieces, part 1 to re-edit, part 2 remains untouched
3: Demux the clip which needs editing
4: Recreate replacement background for video
5: Re-encode new video background (no audio) replacement so it matches video scale / fps / bitrate / exact number of frames as used by original
6: Re-author back together
No audio problems should appear if the correct tools are used
But you haven't mentioned the "type" of video that were dealing with ?
Photo Slide Show in AVCHD
By chrisnewton in forum Authoring (Blu-ray)Replies: 8Last Post: 23rd Apr 2011, 03:40 -
Howdy,VHS to DVD and I want edit to get rid of the dross and add voice over
By rabbithutch in forum Newbie / General discussionsReplies: 3Last Post: 15th Apr 2011, 17:12 -
Only plays 1st title in re-authored/saved as mpg
By John32118 in forum DVD RippingReplies: 4Last Post: 19th Mar 2011, 00:50 -
Memories on TV Photo Slide Show program, help??? Please.
By vanc in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2008, 12:34 -
Retrieving image DAT files from a photo slide show
By cruisebloke in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 10:15
