    Jan 2009
    Greece
    I am looking for software with which I will be able to combine 2 videos in
    order to create a new video which will consist of the 2 selected videos in
    such a way that the left side of the first video and the right side of the
    second video will be mixed.
    Oct 2006
    Canada
    What format are your video files?
    Jan 2009
    Greece
    It does not matter because I can convert them. I just want to find an application which will be capable to do it. It will be good to support AVI format because this is the format that I use with my videos.
    Thank you for your reply.
    Isn't it possible using avisynth? ANy avisynth specialists here?
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    This script does exactly that for DV source. I use it for comparison when doing restoration of old footage.
    # Simple script to do side by side comparison of two clips
    # Handy when doing restoration work to see a quick comparison
    # of the original clip and the restoration work
    # Recommend that the original clip be loaded via a small
    # script that also contains matching trim and colourspace conversion
    # to ensure a match up. Colourspace conversion has been deliberately omitted
    # from this script to reduce needless conversions
    # This version is designed for DV based restoration work
    # and will work for anything with a 720 width.
    # Load clips/scripts
    Orig_Clip=AviSource("cox2 audio.avs").KillAudio
    Rest_Clip=AviSource("cox2 clean.avs").KillAudio
    # Crop clips for comparison. Clips are cropped to create
    # a single complete frame
    Orig_Clip_Crop=Crop(Orig_Clip,0,0,360,0)
    Rest_Clip_Crop=Crop(Rest_Clip,360,0,0,0)
    # Stack the two halves together to finish up
    StackHorizontal(Orig_Clip_Crop,Rest_Clip_Crop)
    Read my blog here.
    Jan 2009
    Greece
    How can I run this script?
    Apr 2004
    Miskatonic U
    Copy it into Notepad and save it with the extention .avs. Install avisynth, then open the avs file in virtualdub or media player classic.
    You will have to change it to reference your videos first.
    Read my blog here.
