I tried converting the avi files with divx 7 , and sometimes it doesn't convert any files, can someone please tell me how to use divx 7 the right way? Sometimes it even makes the video go quicker
Why are you converting? What is your goal with the divx file? Avi files could aldready be in divx/xvid formats. And I also doubt that divx converter supports all video sources so you might have try other converters like avi divx/xvid converters like winff, super,xvid4psp.
Well my goal is to see how good the divx 7 is, they have that HD plus profile, so I thought I'd try it out with some HD videos I got, so I thought I'd try it out, so I should dl Divx 7 and then use programs that support divx 7?
Divx7 uses the Mainconcept h.264 encoder and the MKV container.Originally Posted by Baldrick
How to speed up video conversion
By csc12345678 in forum Newbie / General discussionsReplies: 20Last Post: 15th Feb 2012, 01:43 -
Does a files resolution affect conversion speed?
By perdomot in forum Video ConversionReplies: 4Last Post: 5th Nov 2009, 07:22 -
What Determines Your Conversion Speed?
By bangincaraudio in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:13 -
FFMPEG Stream mapping options result in conversion failure
By JackJack in forum Video ConversionReplies: 6Last Post: 28th Jun 2008, 00:19 -
avi to mp4 conversion speed
By killcorvus in forum ffmpegX general discussionReplies: 1Last Post: 15th Jan 2008, 17:41
