Hello.
I am using KMPlayer to play a video for a presentation that I have.
I would like to use the A-B repeat functionality, but I'm starting the video on startup through a batch file (command line prompt), so I would like to know if anyone knows how to set the repeat a-b function in command line for KMPlayer.
I tried the KMPlayer forum but I received no answers...
Maybe I should use another player?
Thank you.
			Closed Thread
	KMPlayer -> Options -> About -> Command Line Switches
 I see a start option but no end or duration option. You said you did this 3 days ago:
 https://forum.videohelp.com/topic362389.html#1927492
	Hello.
 Jagabo, I moved from KMPlayer to MPlayer because of command line functionality. With the command you told me I can automate the video loop in command line.
 Balrick, that is true. I was under the impression that it was possible to do that. I was wrong actually...
 I going for this player I think. The next challenge will be to improve performance in MPlayer, since it's not the same as KMPlayer...
	Continue in https://forum.videohelp.com/topic362389.html . It's MUCH easier to follow what you are doing if you stay in ONE topic.
  Command-line command for fixing AVI?By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 03:23
  best way to record tv from command lineBy mierdatuti in forum LinuxReplies: 1Last Post: 17th Jun 2009, 03:08
  In the Beginning was the Command LineBy ahhaa in forum ComputerReplies: 2Last Post: 9th Oct 2008, 12:04
  How do I use Lame command line?By rocky12 in forum AudioReplies: 37Last Post: 16th Jul 2008, 22:33
  command lineBy exekutive in forum ffmpegX general discussionReplies: 22Last Post: 2nd Jun 2008, 00:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
