    Jan 2005
    what is that? i'm using auto gordian knot 2.45 and i'm trying to convert the movie "at worlds end: pirates of the carribean". i ripped the movie, it plays fine, no audio out of sync. but when i use auto gk to encode to avi the audio is all jumbled. but it gives me that error "fix d2v tool", well its not an error, but its tell me to use that tool to fix something in the video vobs. is that tool something that auto gk has? anyone run into this ? i need some help. i wanna convert this movie to a ipod video file so i can view it on that.
  2. First, decrypt it correctly. If you didn't use DVDFab HD Decrypter or some other up-to-date decrypter, go back and start over. Second, decrypt only the movie and not the entire DVD. Third, upgrade your AutoGK to get rid of the FixD2V problem. Ver. 2.52 is the latest and that particular problem was fixed long ago.
