I have been using VirtualDub with VobSub textsub filter with no problem, but sometimes it refuses to load the .srt file for no reason that I can see. The video file loads, and everything goes fine until after clicking the .srt file, Open, but the resulting screen shows nothing in the box where the location of the .srt file usually shows. This just happened with 2 subtitles out of 20 for a series I am subbing. Thanks for any advice on how to fix or work around this.
Text coding is ANSI, Unicode or UTF-8?
Old TextSub not support UTF-8.
If these subtitles are encoded in UTF-8...
Open in Notepad and save as with change coding to ANSI.
Or... try latest DirectVobSub (from FileDescription: VobSub & TextSub filter for DirectShow/VirtualDub/Avisynth) - download VSFilter, change extension to .vdf and copy to VirtualDub plugins subfolder. -
Thanks, Placio84, it was indeed the UTF encoding and is working fine now.
Load AVCHD Lite mts files into VirtualDub?
By MJ Peg in forum Video ConversionReplies: 18Last Post: 1st Aug 2012, 13:28 -
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 08:14 -
VirtualDub cannot properly load H.264 Lossless video from AVI or Avisynth
By Jedi787Plus in forum Video ConversionReplies: 1Last Post: 14th Oct 2009, 22:38 -
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:26 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 22:22
