How do you back up both versions after saving it to HDD using AnyDVD HD?
The pro version of DVD-Rebuilder is about the only easy way to do a full reencode of a movie with angles. Or use DVD-Shrink (I think). Or remove one of the angles first.
I guess jah711 means a blu-ray disc? Because this is the blu-ray backup forum.
Oops, I apologize. I found the thread on the front page of your site and forgot to check the forum. In that case, jah711 might give the Beta form of BD-Rebuilder a try. He should probably check at the Rebuilder Forum of Doom9 to see whether or not it handles Blu-Ray movies with angles. My guess, though, is that it does.
http://forum.doom9.org/forumdisplay.php?f=75 -
Yes it does support Blu-ray. I already used that program but it's still in beta testing. I posted this below in their forum concerning my question here:
"Ok...I tried the beta program BD Rebuilder. Everything went thru I guess as far as the long process which I am aware of. It took 24hrs to do the whole disc of Hancock. Disc reads in my PC Blu-ray reader with audio during the ads and coming attractions. There are two versions on this disc...Theatrical and Unrated. Theatrical shows just a frozen black screen when chosen. Unrated played with no audio and was blank for the first 5min of play...which is where the opening credits are supposed to show. Then the beginning of the movie starts to play in whole but with no audio.
What could have happened here?
Thanks."
I haven't received an answer as of yet concerning this...so I am still seeking assistance.
pctv TVCenter versions & multiple installs
By Davalan in forum DVB / IPTVReplies: 0Last Post: 15th Apr 2011, 04:35 -
Re: Audio mixes (theatrical vs. home releases)...
By takearushfan in forum AudioReplies: 4Last Post: 31st Mar 2011, 15:17 -
DVD w/ two versions (theatrical and unrated)... problem
By extrabyte in forum DVD RippingReplies: 4Last Post: 5th Jan 2009, 21:41 -
Problem with FFmpeg with versions 2728 & 2733
By Randalliser in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 5th Jul 2007, 02:40 -
DVD has (2) versions WS & std, how to back up only WS ver ?
By theewizard in forum DVD RippingReplies: 9Last Post: 6th Jun 2007, 16:00
