I'm using nero 7 to burn a wmv-HD video file onto a dual layer disc. My laptop has a dual layer burner but it crashed when I tried to burn the file. I don't believe this is the first time that this has happened.
Here is the log:
SPFFFF
Hewlett-Packard
Windows XP 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.10.1.0
Internal Version: 7, 10, 1, 0
(Nero Express)
Recorder: <Optiarc DVD RW AD-7581S> Version: 4H02 - HA 1 TA 0 - 7.10.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <Optiarc DVD RW AD-7581S >Version: 4H02 - HA 1 TA 0 - 7.10.1.0
=== Scsi-Device-Map ===
CdRomPeripheral : FENIR ZS1Y3OXU78 1.03 aymh5ski Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
Optiarc DVD RW AD-7581S E: CdRom0
FENIR ZS1Y3OXU78 F: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 1478MB (1513788kB)
Memory in use : 47 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.1.2009
UDF compilation
4:11:07 AM #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
4:11:07 AM #2 Text 0 File Isodoc.cpp, Line 6666
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
4:11:07 AM #3 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using DVD media
4:11:07 AM #4 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 4139231 (919:49.56, 8084MB)
4:11:07 AM #5 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
4:11:07 AM #6 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: Optiarc DVD RW AD-7581S, Media type: DVD+R9 Double Layer
Disc Manufacturer ID: RITEK, Media Type ID: D01, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 0
4:11:07 AM #7 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
4:11:07 AM #8 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 4139232 (4139232) = #4139232/919:49.57
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 4139232 blocks [E: Optiarc DVD RW AD-7581S]
4:11:07 AM #9 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [E: Optiarc DVD RW AD-7581S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 8477147136, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 4139232 | 0 | 0x00
4139232 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
4:11:27 AM #10 Text 0 File SCSIPTICommands.cpp, Line 238
Error on LockVolume: Access is denied.
4:11:27 AM #11 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
4:11:28 AM #12 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
4:11:28 AM #13 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
4:11:28 AM #14 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
4:11:28 AM #15 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
4:11:28 AM #16 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
4:11:28 AM #17 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 2.4x (3,324 KB/s)
4:11:28 AM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
4:11:28 AM #19 Text 0 File DVDPlusDualLayer.cpp, Line 494
Disc finalized, LBA total Image size: 4139232 (8084MB), Last LBA L0: 2069615 (4042MB)
4:11:28 AM #20 SPTI -1066 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 00 00 00 00 00 00 21 08 04 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
Buffer x06ec4a00: Len x804
4:11:28 AM #21 Text 0 File DVDPlusDualLayer.cpp, Line 659
L0 Data Zone Capacity set to 2069616 (1F9470h, 4042MB) -> OK, confirmed setting
4:11:28 AM #22 CDR -1205 File DVDPlusDualLayer.cpp, Line 686
Burning Layer 1
4:11:28 AM #23 Text 0 File DVDPlusDualLayer.cpp, Line 696
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
4:11:28 AM #24 Text 0 File Cdrdrv.cpp, Line 9872
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R DL (14), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 22D7FF h (LBN: 1FD7FF h, 4075 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 0 h
Disc Manufacturer ID: RITEK...
Media type ID: D01
Number of Physical format information bytes in use in ADIP up to byte 63: 64
Media Specific [16..63]:
00 00 00 52 49 54 45 4B - 00 00 00 44 30 31 01 40 ...RITEK...D01.@
25 25 37 0C 00 28 64 00 - 28 64 20 1F 0C 0C 14 14 %%7..(d.(d......
02 01 01 20 00 20 1F 0C - 0C 14 14 02 01 01 20 00 ................
4:11:28 AM #25 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: Yes
4:11:28 AM #26 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
4:34:15 AM #27 CDR -1206 File DVDPlusDualLayer.cpp, Line 1969
Burning Layer 2
4:34:15 AM #28 Text 0 File DVDPlusDualLayer.cpp, Line 1980
Perform layer 1 to 2 jump before writing at address 2069616 (1F9470h)
4:34:50 AM #29 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 20 17 00 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x0d1a87c0: Len x10000
0xC6 A1 A9 DF 95 27 63 7F 06 EB E8 CF 99 65 CC 68
0xA3 14 99 B6 72 6D 95 18 CF 98 D0 06 37 93 A7 E2
0x83 8B 81 91 A2 81 80 E5 90 62 16 B7 55 41 2F 13
4:34:50 AM #30 CDR -1135 File Writer.cpp, Line 303
Write error
4:35:38 AM #31 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 2103040
4:35:39 AM #32 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 2.4x (3,324 KB/s)
4:35:39 AM #33 Text 0 File SCSIPTICommands.cpp, Line 261
4:35:43 AM #34 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
4:35:43 AM #35 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Results 1 to 14 of 14
Did you convert the wmv-HD video file to DVD format first(VIDEO_TS and AUDIO_TS folders)Originally Posted by mr-scarface
or are you burning the wmv-HD video file for data/storage?
Newer Ritek discs are pretty much garbage....especially DLDisc Manufacturer ID: RITEK, Media Type ID: D01, Product revision number: 1 -
There are several errors in that log:
I don't think this is your burner, but it should be in DMA mode.=== Scsi-Device-Map ===
I think this is your basic problem. Ritek does not have a good record for DL discs. Try a Verbatim DL + disc and this may solve the problem.Disc Manufacturer ID: RITEK...
Media type ID: D01
This is a general error. Probably related to the disc brand or maybe Nero. I would only use ImgBurn for DL discs as Nero also has a bad record for burning DL discs.4:11:28 AM #20 SPTI -1066 File SCSIPassThrough.cpp, Line 179
This is saying that your burner/software doesn't recognize your DVD media. Again, likely a Ritek or Nero problem.4:34:50 AM #29 SPTI -1135 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x0C
Bottom line, use only Verbatim DL+ media and ImgBurn and your problems may be solved.
BTW, mr-scarface, you should delete the Nero serial number when you post a Nero log. I''ll do that for you.
alright I'm trying to load this wmv file into imgburn by using WRITE as the mode. but the problem is, it keeps saying Invalid or unsupported image file format. Why does it keep thinking I want to burn an image file? I chose "write files to disc" when imgburn loaded up.
edit: I used "build" mode and changed file system option to UDF and now it's burning so we'll see what happens. -
write mode is for disc images only. click mode/build to put it in data burning mode.
The discs may be made by Ritek for Fujifilm.The brand label doesn't mean much, but the manufacturer code does. If that D01 manufacturer code is correct, that's a Ritek disk.
If your burner (Or Nero) doesn't know what the disc is, that may be part of the problem. Some discs don't work well with some burners, and this is especially true with DL discs. Verbatim DL + is about the only dependable DL disc, IMO.
Ok. Well now imgburn got an error during the burn process. I'm going to post the log here but notice that the beginning of it shows that I hadn't enabled UDF mode or something for allowing DL. Also, here's a pic of the error screen I got:
I 15:58:15 ImgBurn Version 2.4.2.0 started!
I 15:58:15 Microsoft Windows Vista Home Premium Edition (6.0, Build 6001 : Service Pack 1)
I 15:58:15 Total Physical Memory: 2,881,220 KB - Available: 1,911,780 KB
I 15:58:15 Initialising SPTI...
I 15:58:15 Searching for SCSI / ATAPI devices...
I 15:58:15 Found 1 DVD±RW/RAM and 1 BD-ROM/HD DVD-ROM!
I 16:04:37 Operation Started!
I 16:04:37 Building Image Tree...
I 16:04:37 Checking Directory Depth...
I 16:04:37 Calculating Totals...
I 16:04:37 Preparing Image...
E 16:04:37 File size exceeds the limit imposed by the ISO9660 file system.
E 16:04:37 Name: C:\Users\IRAN\Downloads\Iron Man Blu-ray Rip 1080p WMV\Iron Man.wmv
E 16:04:37 Size: 8,476,061,158 bytes
E 16:04:46 Operation Failed! - Duration: 00:00:08
I 16:04:48 Operation Started!
I 16:04:48 Building Image Tree...
I 16:04:49 Checking Directory Depth...
I 16:04:49 Calculating Totals...
I 16:04:49 Preparing Image...
E 16:04:49 File size exceeds the limit imposed by the ISO9660 file system.
E 16:04:49 Name: C:\Users\IRAN\Downloads\Iron Man Blu-ray Rip 1080p WMV\Iron Man.wmv
E 16:04:49 Size: 8,476,061,158 bytes
E 16:04:50 Operation Failed! - Duration: 00:00:01
I 16:05:24 Operation Started!
I 16:05:24 Building Image Tree...
I 16:05:24 Checking Directory Depth...
I 16:05:24 Calculating Totals...
I 16:05:24 Preparing Image...
E 16:05:24 File size exceeds the limit imposed by the ISO9660 file system.
E 16:05:24 Name: C:\Users\IRAN\Downloads\Iron Man Blu-ray Rip 1080p WMV\Iron Man.wmv
E 16:05:24 Size: 8,476,061,158 bytes
E 16:05:35 Operation Failed! - Duration: 00:00:11
I 16:07:22 Operation Started!
I 16:07:22 Building Image Tree...
I 16:07:22 Checking Directory Depth...
I 16:07:22 Calculating Totals...
I 16:07:22 Preparing Image...
E 16:07:22 File size exceeds the limit imposed by the ISO9660 file system.
E 16:07:22 Name: C:\Users\IRAN\Downloads\Iron Man Blu-ray Rip 1080p WMV\Iron Man.wmv
E 16:07:22 Size: 8,476,061,158 bytes
E 16:07:29 Operation Failed! - Duration: 00:00:06
I 16:08:34 Operation Started!
I 16:08:34 Building Image Tree...
I 16:08:34 Checking Directory Depth...
I 16:08:34 Calculating Totals...
I 16:08:34 Preparing Image...
E 16:08:35 File size exceeds the limit imposed by the ISO9660 file system.
E 16:08:35 Name: C:\Users\IRAN\Downloads\Iron Man Blu-ray Rip 1080p WMV\Iron Man.wmv
E 16:08:35 Size: 8,476,061,158 bytes
E 16:08:36 Operation Failed! - Duration: 00:00:01
I 16:09:52 Operation Started!
I 16:09:52 Building Image Tree...
I 16:09:53 Calculating Totals...
I 16:09:53 Preparing Image...
I 16:09:53 Contents: 1 File, 0 Folders
I 16:09:53 Size: 8,476,061,158 bytes
I 16:09:53 Sectors: 4,138,702
I 16:09:53 Image Size: 8,476,622,848 bytes
I 16:09:53 Image Sectors: 4,138,976
I 16:09:53 Operation Successfully Completed! - Duration: 00:00:00
I 16:09:59 Operation Started!
I 16:09:59 Building Image Tree...
I 16:10:00 Calculating Totals...
I 16:10:00 Preparing Image...
I 16:10:00 Contents: 1 File, 0 Folders
I 16:10:00 Size: 8,476,061,158 bytes
I 16:10:00 Sectors: 4,138,702
I 16:10:00 Image Size: 8,476,622,848 bytes
I 16:10:00 Image Sectors: 4,138,976
I 16:10:00 Operation Successfully Completed! - Duration: 00:00:00
I 16:10:03 Operation Started!
I 16:10:03 Building Image Tree...
I 16:10:11 Calculating Totals...
I 16:10:11 Preparing Image...
I 16:10:11 Contents: 1 File, 0 Folders
I 16:10:11 Size: 8,476,061,158 bytes
I 16:10:11 Sectors: 4,138,702
I 16:10:11 Image Size: 8,476,622,848 bytes
I 16:10:11 Image Sectors: 4,138,976
I 16:10:20 Operation Successfully Completed! - Duration: 00:00:16
I 16:10:20 Operation Started!
I 16:10:20 Source File: -==/\/[BUILD IMAGE]\/\==-
I 16:10:20 Source File Sectors: 4,138,976 (MODE1/2048)
I 16:10:20 Source File Size: 8,476,622,848 bytes
I 16:10:20 Source File Volume Identifier: Iron Man Blu-ray Rip 1080p WMV
I 16:10:20 Source File Application Identifier: ImgBurn v2.4.2.0
I 16:10:20 Source File Implementation Identifier: ImgBurn
I 16:10:20 Source File File System(s): UDF (1.02)
I 16:10:20 Destination Device: [2:0:0] Optiarc DVD RW AD-7581S 4H02 (E
(ATA)
I 16:10:20 Destination Media Type: DVD+R DL (Disc ID: RITEK-D01-01) (Speeds: 2.4x)
I 16:10:20 Destination Media Sectors: 4,173,824
I 16:10:20 Write Mode: DVD
I 16:10:20 Write Type: DAO
I 16:10:20 Write Speed: MAX
I 16:10:20 Link Size: Auto
I 16:10:20 Test Mode: No
I 16:10:20 OPC: No
I 16:10:20 BURN-Proof: Enabled
I 16:10:23 Book Type Setting: N/A
I 16:10:23 Optimal L0 Data Zone Capacity: 2,069,488
I 16:10:23 Optimal L0 Data Zone Method: ECC Block Boundary
I 16:10:23 Filling Buffer... (40 MB)
I 16:10:24 Writing LeadIn...
I 16:11:30 Writing Session 1 of 1... (1 Track, LBA: 0 - 4138975)
I 16:11:30 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 4138975)
I 16:11:30 Writing Layer 0... (LBA: 0 - 2069487)
I 16:33:19 Writing Layer 1... (LBA: 2069488 - 4138975)
W 16:34:04 Failed to Write Sectors 2102896 - 2102927 - Reason: Write Error
W 16:34:04 Retrying (1 of 20)...
W 16:34:04 Retry Failed - Reason: Invalid Address For Write
W 16:34:04 Retrying (2 of 20)...
W 16:34:04 Retrying (3 of 20)...
W 16:34:04 Retrying (4 of 20)...
W 16:34:04 Retrying (5 of 20)...
W 16:34:04 Retrying (6 of 20)...
W 16:34:04 Retrying (7 of 20)...
W 16:34:04 Retrying (8 of 20)...
W 16:34:04 Retrying (9 of 20)...
W 16:34:04 Retrying (10 of 20)...
W 16:34:04 Retrying (11 of 20)...
W 16:34:05 Retry Failed - Reason: Invalid Address For Write
W 16:34:05 Retrying (12 of 20)...
W 16:34:05 Retrying (13 of 20)...
W 16:34:05 Retrying (14 of 20)...
W 16:34:05 Retrying (15 of 20)...
W 16:34:05 Retrying (16 of 20)...
W 16:34:05 Retrying (17 of 20)...
W 16:34:05 Retrying (18 of 20)...
W 16:34:05 Retrying (19 of 20)...
W 16:34:05 Retrying (20 of 20)...
W 16:38:04 Retrying (21)...
W 16:38:04 Retry Failed - Reason: Invalid Address For Write
W 16:38:05 Retrying (22)...
W 16:38:05 Retry Failed - Reason: Invalid Address For Write
W 16:38:05 Retrying (23)...
W 16:38:06 Retrying (24)...
W 16:38:06 Retry Failed - Reason: Invalid Address For Write
W 16:38:06 Retrying (25)...
W 16:38:06 Retrying (26)...
W 16:38:06 Retrying (27)...
W 16:38:07 Retrying (28)...
W 16:38:07 Retry Failed - Reason: Invalid Address For Write
W 16:38:07 Retrying (29)...
W 16:38:07 Retrying (30)...
W 16:38:07 Retrying (31)...
W 16:38:07 Retrying (32)...
W 16:38:07 Retrying (33)...
W 16:38:07 Retrying (34)...
E 16:38:08 Failed to Write Sectors 2102896 - 2102927 - Reason: Write Error
E 16:38:08 Next Writable Address: 2102256
I 16:38:08 Synchronising Cache...
W 16:38:14 User opted to skip the 'Close Track/Session/Disc' functions.
E 16:38:14 Failed to Write Image!
I 16:38:14 Exporting Graph Data...
I 16:38:14 Graph Data File: C:\Users\IRAN\AppData\Roaming\ImgBurn\Graph Data Files\Optiarc_DVD_RW_AD-7581S_4H02_JANUARY-14-09_4-10_PM_RITEK-D01-01_MAX.ibg
I 16:38:14 Export Successfully Completed!
E 16:38:14 Operation Failed! - Duration: 00:27:54
I 16:38:14 Average Write Rate: 2,631 KB/s (1.9x) - Maximum Write Rate: 3,341 KB/s (2.4x) -
As several others mentioned, Ritek DL is crap, so the normal outcome is what you have experienced: A failed burn.
You might try selecting a slower burn speed (1x, instead of the 2.4x), and fiddling with things like layer breaks, but I would just wait until I bought some decent media before doing much else. It's just a recipe for frustration if you don't use good media (for DL especially). -
Like I said, I will try the verbatim DL discs, but it's strange how it's failing burning because I've burned with these same discs before and the outcome was fine.Originally Posted by tomlee59
mr-scarface,
Besides the inherent quality variation with borderline (or worse) media in general, in this particular case you're trying to burn more than 99% of the disk's capacity. which means you're writing all the way to the outer edge, the most error prone part of the disk, and where the flaws in inferior media become critical. Both burns failed shortly after switching to the second layer, at the outer edge of the disk....it's strange how it's failing burning because I've burned with these same discs before and the outcome was fine.
In any situation where the material you're trying to burn is close to the capacity of the disk, you should use only the best media. That would be Verbatim +RDL in this case, which is what has been recommended to you earlier.
It wasn't the reason for failure in this case, but ImgBurn is repeatedly telling you the large file size exceeds the maximum allowed by the ISO 9660 specification. When you're burning large files like this, you should make it a UDF only disk (drop the ISO 9660 part). -
Part of the problem with cheaper discs, and this includes single layer and double layer discs, is that the media is not consistent. You may have a good burn with one batch and the next may fail. This can also happen within a cakebox of discs. Another good reason that cheaper brands of discs are not all that economic a choice.
Some members have good luck with Ritek DL discs, but that is usually because they lucked out with the right combination of burner and disc.
But try a Verbatim DL disc. I have yet to have a coaster with them. And that's using several brands of drives. If you still have a failure, consider a external burner instead of your laptop drive. -
That is your problem not to mention you are using Ritek DL and a laptop writer.E 16:04:37 File size exceeds the limit imposed by the ISO9660 file system.
Yeah, I started the burning process only after I chose UDF as file system. I think I mentioned that in my OP.Originally Posted by VegasBud
Anyhow, i'm gonna have to order some of those verbatim discs. I don't want to throw out the Ritek ones so I guess I'll try burning again but only at 1x and not filling up the disc so much as was recommended.
Virtualdub just crashed, Resume?
By Asesinato in forum RestorationReplies: 8Last Post: 4th Apr 2012, 12:10 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Crashed and recovered
By Fluf in forum Newbie / General discussionsReplies: 21Last Post: 7th Jan 2009, 09:16 -
My PC Crashed and Don't know what codecs to get!
By faramith in forum Newbie / General discussionsReplies: 1Last Post: 1st Jan 2009, 10:39 -
My Computer Crashed. I Can't Start It Up.
By moviebuff2 in forum ComputerReplies: 28Last Post: 29th Sep 2007, 11:34
