Who wants HDPVR support on the Mac?
http://steventoth.net/blog/hdpvr-capture/features/
Additional support:
http://www.avsforum.com/avs-vb/showthread.php?t=1081590
This tool is great, and the developer that created gives top notch support.
Capture from your Hauppauge HD-PVR to your Mac.
Application Features
1. Records HD video resolutions 720p and 1080i via the rear component input into H.264.
2. Records SD video resolutions 480i/480p via the front svideo or composite inputs.
3. Records 2 channel AAC or 2 channel AC3 via the front or rear RCA jacks
4. Records Digital AC3 2.0 or 5.1 audio via the rear SPDIF connector.
5. Playback your 720p or 1080i recordings in VLC or Plex (system load will be high)
6. Encode using bitrates from 1mbps up to 20mbps
7. Converts 720p recordings into .mp4 Quicktime compatible files
8. Quicktime compatible files are automatically added into your iTunes movie library.
9. Supports 700+ STB vendors and over 1000 different remote handsets via the IR Blaster.
10. Video Encoder Bitrate support from 1mbps to 15mbps, in Variable or Constant mode.
11. Integration with TitanTV to allow you to schedule recordings from their EPG website.
12. Integration with iCal if you’d like to create your own custom schedules.
13. Simple drag and drop interface for converting files into MP4, it’s simple!
14. Use TitanTV and your zipcode to automatically download and configure your channel menus. No need to enter tens or hundreds of channel names manually. It’s fast and simple.
Chris -
The nearly finished EyeTV 3.1 software will support the Hauppauge HD DVR.
Capture Software for Hauppauge HD-PVR
By DarrellS in forum Capturing and VCRReplies: 41Last Post: 26th May 2013, 20:24 -
Set to Capture @ 720p on Hauppauge HD-PVR?
By yic17 in forum Capturing and VCRReplies: 4Last Post: 16th Jul 2011, 20:48 -
capture VHS with Hauppauge PVR 150?
By shun in forum Capturing and VCRReplies: 13Last Post: 24th Jul 2010, 19:11 -
Hauppauge HD PVR (Capture PC gameplay)
By TommyGun in forum Capturing and VCRReplies: 2Last Post: 14th Jun 2010, 10:50 -
hauppauge hd pvr 1212 Capture Issues
By jwack in forum Capturing and VCRReplies: 10Last Post: 19th Nov 2009, 21:17
