Results 1 to 11 of 11
  1. I have a Gateway Media Center PC GX7022E with an Intel D945GBI motherboard (http://support.gateway.com/s//MOTHERBD/Intel2/WMEOEMD945GBIG1/WMEOEMD945GBIG1nv.shtml) and a 82945G/945G Intel Chipset (Gateway 2000 82945G).
    I've been reading threads that say that a motherboard with a 945G chipset can't support a Core 2 Duo processor when on Intel's site says they can.
    http://www.intel.com/products/desktop/chipsets/945g/945g-overview.htm
    This PDF says the same thing but in more detail (just type Core 2 Duo in the search box).
    http://www.intel.com/Assets/PDF/datasheet/307502.pdf
    Are there 945G chipsets that can't support Core 2 Duo, and more importantly, can my motherboard support it?
    There is a 1066MHz FSB limitation on my motherboard so 1333MHz Core 2 Duos will obviously not work.
  2. There is a 1066MHz FSB limitation on my motherboard so 1333MHz Core 2 Duos will obviously not work..
    THey might actually work, and work well, but you might have to fiddle about with the FSB speed and/or get an unlocked chip .. or just run it 266mhz slower-er than normal..
    The electronic components of the power part adopted a lot of Rubycons.
  3. I was leaning towards the E7300 or the E7400 and was wondering if processors like those would work on my motherboard.
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010340343%201051707842%20...2&name=1066MHz
    I've never heard of a 1333MHz CPU working on a 1066Mhz motherboard and I really don't want to risk spending money to find out. But if it does, I'll take the E8500 right now.
  4. Originally Posted by seven_deuce offsuit
    It will work, it will just run 20 percent slower.
  5. How would an E7400 1066 @ 2.8GHz compare to an E8500 1333 @ 3.16GHz running 20% slower?
  6. The difference between upgrade and building a new system is not much and what will you do with the parts you take out. That said check these options
    Buying CPU in places like frys you get a motherboard included RAM in these days is around $30 after rebate.
    You can get a G31 motherboard for $50 it accepts all kind of CPU it also has built in graphics very stable you can add your video card too.
    If you do video work mostly go for Quad. Tell us how much you want to spend? we'll give you suggestions.
  7. Well, I was actually just looking to only upgrading my CPU until I save up for a Core i7 build in the future (which is going to take a while).
    But if I were to build a budget rig it would look like this.
    I compiled this list rather briefly and altogether adds up to about $500 excluding shipping and taxes, so it might end at around $575. What do you guys think? Any suggestions on how I can make this budget PC cheaper, keeping in mind that I do a lot of video editing and encoding? Or is the price good enough for a budget build?
  8. Originally Posted by seven_deuce offsuit
    The E7400 will be running at its rated clock speed of 2.8 GHz. The E8500 will be running 20 percent slower than its rated clock speed, about 2.5 GHz. Although the E8500 has more L2 cache the higher clocked E7400 will be faster in most applications.
    You may need a BIOS update to support the new CPU. Perform the BIOS update before installing the new CPU.
    Intel quad core price cuts on Jan 18?
    http://www.theinquirer.net/inquirer/news/390/1050390/intel-price-cuts-loom
  9. I have a similar motherboard on my Gateway - an Intel D945GCZ.
    It's operating voltage is 1.25 - 1.4V
    The Core 2 Duo is 0.85V – 1.3625V.
    This difference is one of the reasons I chose not to upgrade the CPU since the board doesn't permit voltage adjustment. There was another which quashed my excitement at the time but I can't recall what it was.
    Nov 2002
    If you're going to use onboard video, I'd go for a G43 or G45 chipset. The G945 doesn't support HD and neither does the G31.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128354
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128353
    Five SATA connectors, eSATA, Firewire, DVI and HDMI
  11. I have an ATI Radeon HD 4850 that I bought off a friend for only $100 so I jumped at the chance and it works perfectly. I have plans on using it on the G31 for HD support if I decide on getting that particular motherboard.
    Wow, now I'm feeling more inclined to make a new build. Thanks for the good news!
