Hi,
I have been using avi.net v2.5.8.0 for a while now to convert small files from dvd .vob files to .avi files. It has worked fine until yesterday. I did a batch and the last file wasn't created. So I redid that file by itself and it went through the process way too quickly and when it finished there was no .avi file output.
I tried again, same result. So I used another program, it worked but the results weren't as good. Think I used the Xilisoft converter. Anyway, today I uninstalled avi.net and downloaded and installed the newer version 2.8.5.2. However the same thing is still happening. Any ideas what's going on???
Thanks,
MC
It doesn't work with any file. I'll see if I can find a log file. It shows what it's doing as it works on it but it's way too fast.
Thanks,
MC
ffmpeg won't convert files from Pal to NTSC, mpegstreamclip does
By ruggerjvd in forum ffmpegX general discussionReplies: 2Last Post: 8th Jun 2009, 08:39 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 10th Sep 2008, 23:02 -
AVI won't burn in Toast 7 (need to convert or repair?)
By 3lutz3toe in forum ffmpegX general discussionReplies: 4Last Post: 1st Aug 2007, 16:07 -
SVCD2DVD won't launch after latest Windows Update of MS .net framework
By starkraving in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Jul 2007, 03:42 -
Panasonic TOUGHBOOK 19 Notebook, won't reconnect to net after being closed
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 15th May 2007, 05:01
