  1. Hi guys.
    How can i set a specific subtitle to be shown by default?
    can it be done without demuxing/remuxing?
    Any help would be greatly appreciated!
    thanks in advanced.
  2. I think this is more a function of the specific DVD player, not the authoring process
    (unless you meant forced subs...)
    http://www.doom9.org/index.html?/forcedsubs.htm
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Originally Posted by GangstaRap
    Hi guys.
    Some DVD authoring apps allow you to set this (GuiForDVDAuthor, e.g.).
    Otherwise, after authoring the VIDEO_TS fileset you can edit them with PGCEdit.
    Just follow these instructions.
  4. Thanks poisondeathray,
    i dont know what "forced subtitles" means (embedded?), but i'll read your link.
    Thanks AlanHK.
    i think thats what i was looking for,
    just didnt think it would be so comlicated... :P
  5. It's not complicated. It just looks complicated. That guide covers all the possibilities. Once you've done it a couple of times it'll take all of about 15 seconds to do.
  6. yes.
    in first look it seemed complicated,
    actually its pretty easy.
    Thanks a lot for this useful link!
  7. Member MysticE's Avatar
    Nov 2003
    If it's only a movie DVD Shrink works well.
  8. Member blutach's Avatar
    Apr 2007
    Australia
    Meaning a re-authored movie. Right click on the title and use set default streams. BTW: Some rippers, especially in movie only mode, allow you to specify a stream to be on by default.
    Regards
    Les
