folks,
the last time I captured stuff from my taperecorder onto harddrive is 4 years ago. Now I use a complete new machine runnin vista64 with a Radeon HD 3650 card with svhs-IN. BUT unfortunately I can't get a signal. I guess the reason is a driver issue - at least I don't know which I should install. The catalyst 8.2 should have WDM installed but I can't get a signal.
Any ideas?
I'm pettey sure the reason is not driver issue but there are not designed with video input.
From the ATI webpage:
Note: All-in-Wonder™ boards operate with AMD Windows Vista-Ready Display Drivers under the Windows Vista Operating System. However there is currently no software application which provides TV/Capture functionality for All-in-Wonder™ boards under Windows Vista.
My brother has Vista running on a Dell PC he bought from their website and the only software that works with the capture card in the machine is something that Microsoft wrote that's part of Vista. -
I think what SHS was saying is that he believes the OP's Radeon HD 3650 card uses its S-Video port for output, not input. If that is true, the only way to fix that problem is to replace it with another graphics card, or install a capture card with s-video in.
ok i see... I guess this is correct cause my google-search found no result at all. damn...
The new HD AIW will only work correctly on a Vista machine. It does not support clear QAM in XP nor do the HD TV Wonder cards. I believe you also have to use the software that comes with the cards, Catalyst Media Center (I think it's Cyberlink Powercinema).Originally Posted by jman98
help with capturing from various analog devices
By TARfan in forum Capturing and VCRReplies: 4Last Post: 19th Mar 2010, 12:36 -
Capture analog with camcorder or ATI card?
By Onceler2 in forum Capturing and VCRReplies: 7Last Post: 28th Nov 2009, 08:25 -
I've got $3600 for a camera. Has anyone any recommendations?
By deanj in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 23rd Jul 2009, 15:05 -
Crazy, wavy black lines on capturing from jerky video (images&vids in p
By osteopants in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2008, 12:25 -
Need some help capturing Analog video
By zagorski in forum Capturing and VCRReplies: 5Last Post: 10th Dec 2007, 20:27
