  1. Hello all,
    I am taping in a SECAM-area and have the possibility to use a good NTSC-camera over a (bad)nother PAL camera.
    I was wondering how difficult it is to convert the NTSC- end product to PAL?
    Any experts out there? Any program suggesting?
    Thanks a lot!
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Consider just making it NTSC and not converting.
    I think most TVs in PAL countries are multi-system, they can display NTSC as-is. Mine certainly does.
  3. Member zoobie's Avatar
    Feb 2005
    Florida
    True most play both these days yet I'd like to run my NTSC DVD on a PAL player and TV set running at 50 cycles per sec to actually see how well it comes out...
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I do it all the time, no problems.
    Sometimes I make DVDs with both PAL and NTSC features, also no problems on the several machines and TVs I've tried here, though these are probably strictly out of spec.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You couldn't tell the difference. I have the movie CARS in NTSC and PAL versions
    and cannot tell them apart.
    Oct 2006
    Canada
    How do you do this in Colorado?
  7. Member zoobie's Avatar
    Feb 2005
    Florida
    ha ha...I don't
    so burnt one's come out ok?
    I remember getting PAL VHS from Europe...It played all green
  8. Thanks folks for all the answers... I feel relieved and up to taping NTSC - when needed - in a PAL surrounding
