Can anyone recommend a good graphic cards that satisfies the following:
- silent cooling (no fan, just a silent pipe)
- HDMI out (for TV)+ DVI out (for monitor)
- 1920x1080p support video out + 5.1 sound out through HDMI
- built-in HDCP
-i would like to use both HDMI out and DVI out together (if it is possible at all)
one for monitor and one for LCD TV.
-if it is not possible to use together than a t least just to be able to switch it in PC soft easily to choose screen output between monitor and LCD TV (most of time to watch movies on LCD TV 1920x1080)
is the any cards on market to handle this?
(i dont play games just need it for watching movies from my PC)
thanks to all
Perhaps:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127301
Read the reviews, sounds like you'll still need to cool it down.
Better:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127386
The heat sink might be too tall for your PC
The fan is very quiet on this card, I'd get this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121267 -
thanks for input
i think all are nvidia cards
is there also some ATI based silent versions like this with hdmi out? -
That card isn't silent. Here are a few fanless ATI cards:Originally Posted by Soopafresh
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048%201305520549&pa...silent&bop=And
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Successfully split a consumer (i.e. with HDCP) HDMI connection ?
By dLee in forum DVB / IPTVReplies: 3Last Post: 4th May 2011, 12:19 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 19:32 -
DVI - HDMI - DVI problem
By rbjt in forum Media Center PC / MediaCentersReplies: 0Last Post: 4th Aug 2009, 23:14 -
Philips DVP5960 HDCP Question /// HDMI -> DVI and Composite Audio?
By cactusPhone in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th May 2007, 22:32
