I wanna do some transitions on my DVD,here is my situation:
I have a motion menu with 2 cells, in which the buttons are all appear
in cell2, then I do the transition within main menu and the scene selection
menu,but the transition changes the scene in cell1 instead of cell 2 which I
want to be, can DLP do the transition using the scene in cell2 instead of cell1?
Save yourself a lot of grief and get better quality by creating your motion menu backgrounds in another program, like a good video editor. It gives you far greater control. You can then encode them to mpeg-2 DVD compliance, and import them into DLP for authoring.
I have been using DLP for years, and I have never, ever created a motion menu inside DLP. I always do it outside DLP, and use DLP simply for authoring.Read my blog here.
You have one motion split into two cells. That is why transition will start from beginning in cell one.
If you want to do it any other way you will have to go with guns1inger's advice or make two start menus, where the second one will have buttons. -
thanks for you guys advice~~
It seems a little bit troublesome.
One more question:
Is it possible for the subpictures have more than one color?
Problems copying .VRO files from DVD-RAM -- SOLVED!
By usually_quiet in forum DVD RippingReplies: 14Last Post: 2nd Jun 2011, 17:30 -
FPS-related problems in Premiere when importing a video (solved)
By quandore in forum EditingReplies: 4Last Post: 4th Nov 2010, 07:04 -
LG LRH-780 DVD Drive Problems..... Solved!
By dragon064 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Feb 2010, 20:59 -
[SOLVED] Problems running dvdrebuilder in wine
By freebird73717 in forum LinuxReplies: 3Last Post: 10th Mar 2008, 13:44 -
SubtitleCreator Problems (Solved)
By TRUSTpunk in forum SubtitleReplies: 9Last Post: 8th Aug 2007, 13:05
