hello i have a bought dvd that im trying to backup but it has a bad bit on the disc
clonedvd will copy it but when i try to write is says file size to large (maybe something to do with the retries)
and yes i selected the correct settings as i have been using it for a long time..
I can also get an image of the disc with imgburn after a few retries but no errors but the filesize is to big
so how do i get an imgburn image (6.9 gig) to dvd files reducing it at the same time or reducing it after as long as i end up with dvd files (VIDEO_TS)
Try dvdfab hd decrypter and rip to the hdd or an iso and see if it works better.
You can shrink image/isos using dvd shrink. -
if you shrink 6.9 gig that is about %60 compression you won't get good quality playback. Use a DL dvd.
doh and double doh i had the dvd9 ticked thats why i could never get it to fit
I always use dvd5 but last time set it at dvd9 for a music dvd backup lol
now i feel a bit stupid
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad motherboard or bad CPU?
By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 10:07 -
Bad Disc check program?
By BrokenOne in forum MediaReplies: 2Last Post: 10th Mar 2008, 23:40 -
bad disc error, what's the perfect convert/burn setup?
By macnolias in forum Video ConversionReplies: 4Last Post: 16th Nov 2007, 18:44 -
Bad burn - Panny E30 or TY disc?
By jdachik in forum MediaReplies: 5Last Post: 21st Jul 2007, 10:42
