I have loads of DVD images (VIDEO_TS folders) stored on my HDD, and, instead of burning hundreds of DVDs, I want to keep them on the drive and play them from there. So my questions are:
1. Is there any DVD player/recorder out there that can play VIDEO_TS folders via USB? (converting all to DIVX is not option since there is too much workload and quality loss)
2. Would it be better to get a Windows Media Centre? In that case, can it play the VIDEO_TS folders? (I have no experience with Windows Media Centre, but I would be happy if it has something like POWER DVD, which can read the IFO files.
Thanks.
1. Nope. But you can get a Media center like the popcorn hour, see http://www.networkedmediatank.com/showthread.php?tid=11857. Or an old xbox with XBMC.
2. http://www.wictorwilen.se/Post/Watch-DVDs-in-VIDEO_TS-folders-on-Vista-Media-Center.aspx . Or you can use whatever htpc software if you build your own htpc, like xbmc, media portal, etc. But this will probably cost much more then a popcorn hour media center box. -
Unless I'm mistaken the new WD HD boxes handle images.
Google is your Friend
Playing Media Files on Samsung TV Through the USB Port
By twentyroses in forum Newbie / General discussionsReplies: 13Last Post: 5th Sep 2011, 08:01 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
dvd player with USB port (with NFTS support)?
By themaster1 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 10th Nov 2009, 20:33 -
DVD Players with USB 2.0 port
By nicoarad in forum DVD & Blu-ray PlayersReplies: 12Last Post: 28th Oct 2008, 22:06 -
DVD player with USB port
By Scooby Doo 12345 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Oct 2007, 09:35
