I have downloaded some .asf stream files (.wmv) with GetASFStream program. How can i make them work on my stand-alone DVD-player?
Not many players support the WMV/ASF format, you may have to convert the files to either DVD or XviD (if your player supports it).
Plenty of programs and guides on this site to help you do that...
Well, i have first converted those files to AVI using ASFTools. Then opened with VirtualdubMod. But converting to Xvid doesn't seem to work. Video is all messed up (purple green mess) when converting. Also the file size is going to be very very big, compared to the original file size.Originally Posted by mh2360
I don't recommend either of the programs you tried. If you buy the commercial Divx codec, you can use it with Dr. Divx. If you don't buy the codec, Dr. Divx limits the quality of your encodes but it will still work. AutoGK can probably do it too and it can use the free Xvid codec.
The size you get when encoding depends on the bit rate you use and it shouldn't necessarily be much bigger than the original file. In my experience WMV and Divx/Xvid compress about the same.
How to record streaming WMV/ASF/MMS-links using VLC Media Player
By Baldrick in forum User guidesReplies: 58Last Post: 27th Jul 2012, 11:10 -
Cannot play ASF (WMV) files in Windows Media Player
By javaluvva in forum Software PlayingReplies: 3Last Post: 15th Jul 2010, 22:57 -
Anyone knows how to convert ASF / WMV to Mpeg2
By macuser1960 in forum ffmpegX general discussionReplies: 3Last Post: 9th Feb 2008, 17:38 -
dvd player with the best compatibility?
By JCWagener in forum DVD & Blu-ray PlayersReplies: 23Last Post: 16th Nov 2007, 22:17 -
Converting an ASF (WMV) file
By yadda in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2007, 07:16
