I'm trying to edit an .srt file with SubCreator (I want to erase the background sounds), but I noticed that opening/converting the .srt all the – begin †or … adding to all the stuff that I have then to edit manually.
I like SubCreator because I find it easy and straightforward but there is a way to solve that? also, wich other software could I use?
thank you
Or a text editor would work fine like notepad ++....
thank you both. subsworkshop does the same, it read the - (long trait) as … ...
I'll do it with notepad next time, after all it has the find function..
How to demux .srt from mkv, then convert .srt to .smi and mux .smi to mkv??
By narayanan in forum SubtitleReplies: 1Last Post: 7th Aug 2010, 22:49 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 00:46 -
Opening a file
By ahidayat in forum Newbie / General discussionsReplies: 1Last Post: 2nd Mar 2009, 04:33 -
Opening Movie
By Gunna in forum Newbie / General discussionsReplies: 7Last Post: 13th Sep 2007, 17:08 -
Inserting Opening
By zirkov in forum Video ConversionReplies: 2Last Post: 27th Jul 2007, 13:53
