I'm trying to convert a relatively small .MKV file [about 150 mb] for playback on my ps3.
Everytime i attempt to use mkv2vob, the transcoding stops prematurely and i get an unplayable file, only a fraction of the original e.g. the output i got was around 37 mb. What can i do to fix this?
If you choose copy for audio and video formats then the quality is unchanged. MP4 has very low overheads, so the file increase is not huge. m2ts has much larger overheads, so expect to see the file size increase by around 6 - 8%. This is an issue with the format, and cannot be avoided. All you are doing is repackaging, so there is no re-encoding.
If you do need to re-encode, because the contents of the mkv aren't in the correct format, there are several settings you can use, from quality based through to 2-pass bitrate based. Use whichever is appropriate.
What formats are in the mkv file ?Read my blog here.
I'll try using it for the mp4, but do you know what settings are optimal to play on a ps3?
The PS3 will play pretty much anything you throw at it, but use the templates in Xvid4PSP if you are encoding from scratch. The few mp4 and mkv files I have worked with have not needed to be re-encoded to play, as the audio and video content have been PS3 compliant. Why screw with something that works. I have also used Xvid4PSP to repackage quicktime HD 1080 trailers to m2ts format without having to re-encode. They have all played fine.
Read my blog here.
mkv2vob please help
By miconba in forum Newbie / General discussionsReplies: 5Last Post: 24th Jul 2011, 17:18 -
mkv2vob always hangs on dts to ac3 and problems with PS3 media server
By BirdDaddie in forum Video ConversionReplies: 3Last Post: 15th Aug 2010, 18:08 -
MKV2VOB Audio Problems
By mnalmeid in forum Video ConversionReplies: 2Last Post: 29th May 2010, 18:03 -
MKV2VOB sound problems
By DaxPG in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 15:43 -
mkv2vob and avi playback problems on pc
By craig198 in forum Newbie / General discussionsReplies: 4Last Post: 14th Aug 2008, 15:53
