    Sep 2004
    I use pgc edit for one thing. To import a first paly them make an image file to burn. The function stopped working. I used to add the ifo and it gave me the option to copy or move the vob. It stopped giving me that option and the finished product has no startup clip. I am using version 7.4 HELP!!
    Ken
  2. The first thing you might try is updating your PGCEdit. Yours is over 2 years old now.
    Sep 2004
    I tried that and the same thing happened.
    Sep 2004
    I figured it out. The VOB that I have used many times was gone. Where it went I don't know. I was able to replace it - so all is fine now.
  5. Banned
    Freedonia
    kshavo - PgcEdit has nothing at all to do with VCD/SVCD. Please post such questions in the appropriate forum in the future. Authoring (DVD) would have been a better choice.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Moving you to our dvd authoring section.
