I have a 1080i .TS (mpeg transport stream) format file that is widescreen and has 5.1 PCM, I want to convert it to MPEG-2 to burn onto a 480p DVD while retaining the 5.1 audio. Somebody please help. I've been searching everywhere and have had no luck! .TS is a file format that
Xvid4PSP should be able to load the TS file and output DVD compliant mpeg-2 video. You will have to convert the audio to AC3 to retain all 6 channels unless you want the video bitrate to be very, very low. I cannot confirm if Xvid4PSP convert multi-channel PCm to multi-channel AC3, but I suspect it can.
Read my blog here.
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
How can I convert a 1080i ".TS" file to DVD-compliant MPEG-2
By kiwisoup in forum Video ConversionReplies: 1Last Post: 11th Jan 2009, 18:53 -
"Unsynched repair block" on 1080i .TS HDTV file
By Pliny in forum DVB / IPTVReplies: 1Last Post: 13th Jun 2008, 03:57 -
The "convert a single VOB file to a DVD" project!! :)
By djdust in forum Authoring (DVD)Replies: 42Last Post: 23rd Feb 2008, 08:49 -
DVD Players that "upscale" to 1080i
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2008, 17:01
