I have a few DVDs of scanned photos. I'm not using any slideshow programs. But have about 10 folders of photos on each DVD. If I play them on the DVD player I can only get the first three or four folders to play. All the folders show on the TV but the last ones appear empty. (I've checked the DVD on the cpomputer and the files are all there)
Most DVD players have a limited number of files they can read. Some limit subfolders read.Originally Posted by didikai
Check the manual. Do a search on your player.
CDR is usually sufficient for jpg only.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Not all firmwares are equal. Read the manual of your standalone and
check how many folders and files per-folder/per-disc it does support.
HTH.
P.S.: Still slower than edDV!
avi won't play
By fabre in forum Software PlayingReplies: 2Last Post: 25th Aug 2011, 00:26 -
JPegs don't play in correct order on DVD player
By NichoPhoto in forum Newbie / General discussionsReplies: 12Last Post: 3rd Feb 2010, 08:11 -
.ogm Won't play
By shiroshadows in forum Software PlayingReplies: 8Last Post: 2nd Jan 2010, 20:38 -
MP4 won't play
By lilblu in forum Software PlayingReplies: 3Last Post: 15th May 2009, 00:25 -
'Some' disks won't play...
By Anonymous4374945 in forum Newbie / General discussionsReplies: 7Last Post: 30th May 2007, 17:14
