hi, i got these files
filename.001-002.zip
filename.003-004.zip
filename.005-006.zip
filename.007-008.zip
filename.009-010.zip
how can i open it ? so far have try using winrar, 7-zip, winzip , but no luck
	How large are they and where did they come from?
 It is possible that they aren't zip files at all. If they are small (a few K), open one in Notepad and see if the first two letters are MZ. A lot a malicious programs claim to be zip files but aren't.
 Also, is your Windows configured to show the extensions of files in Explorer? e.g., if it isn't, valid extensions such as zip, bmp, avi etc are hidden and you should only see the first part of the them. This is how Windows works out-of-the-box. If you are expecting them to be hidden but still see the zip extension, it means the file is really something else - e.g., fred.zip.exe will show up as fred.zip unless you have changed Windows to show extensions.
	Try renaming the files 1.zip, 2.zip, 3.zip, 4.zip and 5.zip
 Sometimes multiple . in filename causes trouble.
	HJ Split http://www.freebyte.com/hjsplit/
 browse to filename.001zip and Join
	Here you go
 Code:http://rapidshare.com/files/182256880/fsjsetup.rar
	each files @ 200,000 KB
 and you can't rename it too
 and fsjsetup not recognize it too
 just found out
 i use pkzip to devide between 001-002 , 003-004, ... become .01 .02 .03 .04 ...
 then use Hjslit to join it
 thanks for all your help
  downloaded SVCD2DVDv2.5.zip won't openBy bobarnett in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 6th Aug 2011, 16:48
  No Video Signal EasyCap Model 002By WESIDA in forum Capturing and VCRReplies: 0Last Post: 9th Feb 2010, 12:49
  extracting the bin/cue from .oo1,.002 etc filesBy belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 01:59
  ? .mpg.001 etcBy rotuts in forum MacReplies: 3Last Post: 5th Nov 2008, 00:55
  What do I do with <filename>.avi.001 files?By Hank Kinsley in forum Newbie / General discussionsReplies: 5Last Post: 26th Aug 2007, 06:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
