Hi all,
I got a bunch of DVD-r's with left channel only audio. I'd like to re-author these and convert the left channel to mono. Obviously I'd like to do as little re-compression as possible. Any ideas?
Strip out the video and audio using pgcdemux.
Reconvert the audio to mono ac3 using some audio software like daudiok, belight etc.
Use muxman to author the old video with the new audio. You can now burn the VIDEO_TS folder or
Add back the menus from the old dvd using vobblanker.
If the DVDs contain several tracks it wont be that simple though.
movie with two ac3 2-channel audio tracks one is mono, which one?
By pm1315 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2011, 14:14 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 17:47 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 01:45
