Hello, I've tried pinnacle 8, 12, Corel, adobe 6 and adobe 1.5 and all have issues and seem to close or crash at random for various reasons.
Pinnacle doesn't playback smoothe and hangs constantly when trying to render to tape. Corel videostudio 12 can't load library and for that, doesn't render at all. Also when I save a title and re-open it, all of the styles are changed.
Adobe 6.5 crashes when the titler is in use and adobe pro 1.5 wont capture for more then a few seconds at a time.
I personally like the Pinnacle 12 the best but what's the point if it can't play back in a decent quality to check your work, or print to video without hanging up.
My system is new, plenty of ram and speed. My computer guy says it's just glitches with the programs. We've tried many drivers.
Do you guys have these issues? If so, can someone throw some advice this way and perhaps recommend a stable editing program? I defrag daily as well!
Many thanks, Tim
You should be getting better results than that. You are using very old versions of these programs which may be a factor.
In my experience, Sony Vegas is most stable. I haven't used the recent consumer Movie Studio versions so can't comment.
Next best from your list is probably Corel-ULead Video Studio 12. Did you install bug fix updates?
Pinnacle Studio and Roxio products have a poor history for stability.
Adobe Premiere 6.5 (2002) was the last of the original Premiere series and was reasonably stable but every version before that had serious issues. v6.5 is good for DV source.
Adobe Premiere Pro 1.5 (~2004) was a rewrite and had issues. 2.0 improved things. Current version is CS4.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I may have too many video programs- I cannot get my capture to work
By FLVidiot in forum Newbie / General discussionsReplies: 0Last Post: 6th Aug 2010, 00:45 -
Editing Programs.. Hopefully freeware
By sgt_hanky in forum EditingReplies: 2Last Post: 9th Dec 2009, 07:09 -
Will my video programs, codecs, etc, still work with Windows X64?
By HartsVideo in forum Software PlayingReplies: 15Last Post: 5th Sep 2008, 14:09 -
cannot get video into editing programs
By hailmary in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2008, 01:43 -
conversion programs just won't work!
By Sean O'Scare in forum Video ConversionReplies: 19Last Post: 17th Feb 2008, 02:58
