i have a movie and i have the subtitles too it, but i have no ide how to burn it as a vcd. I have nero 5.5.0.3 and alot of weird tools that i can't use, tmpgenc, virtualdub and so on..any help would be highly appreciated...
not sure it helps to know...but the movie is in .avi format and the subtitles are .srt files.
Maybe this helps:
convert the *SRT file to *SSA.
Load the AVI file in Virtual dub, add the subtitles with the subtitle filter, frameserve, and encode with TMPGEnc. (I suppose you want to create a VCD or SVCD)The Dutchman -
yes, i want to make a vcd..thanks...
but i can't get it to work... tmpgenc says that it's not a valid file, to compressed. and virtualdub is just a mess. But i'll keep trying, maybe i'll get it right...otherwise i'll ask for some more help... -
I tried to add the subtitles using the filter on VirtualDub, but when I select to start frame server, that little box "frameserver mode" appears on the screen and just stay there forever. There aren't any progress bar or time left. Does anybody know how long I have to wait to, then, convert it to SVCD??
The frame server is doing just that, serving frames to another program (TMPGenc). Just load up the frame server file into tmpgenc (or whatever your encoding with) and vdub should serve the frames with the subs in place (assuming you have that part setup correctly).
wh -
BINGO!!!
It worked!!
Thanks!!
Hmmm, could I ask you just one more question??
I am experiencing problems when loading some video files on VirtualDub. I have a lot of DivX files that when I try to open on VirtualDub, it says that the audio have to be recompressed otherwise I'll have some seconds of "skew from the video stream".
Do u know how can I fix that?? -
I am trying to do this following the guide on this site but TMPGenc just sits whilst checking the frameserver file ( *.vdr ) . Is there something else that needs to be set up in TMPGenc or VirtualDub ? I have tried on 2 machines with 3 different versions of TMPGenc .and vdub should serve the frames with the subs in place (assuming you have that part setup correctly).
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10
