Was using Gotsent successfully but after formatting PC I'm having trouble. I end up with an MP4 file about 160mb in size which just contains the audio. When Gotsent is running, it extracts video fine, I get a temp h.264 file about 5gb etc, but its when it muxes the mp4 that I just end up with the audio. My codecs seem to be OK as MP4s and MKVs etc all play fine in MPC and WMP11. Any ideas?
I had that same problem with the audio being in the file but no video. Two things helped:
-I removed the Nero AAC encoder and went with the default
-I renamed all my source files from This.TV.Episode.720p.some.other._bad_.characters.m kv to just episode.mkv
Both of those helped... GotSent is still spotty at best but it's working ok for me now. Still having language encoding problems though... nothing that comes up with any language other than "undefined" or "eng" will work. I'm currently trying to work through creating a new eng.po file for the ac3 filter and hoping maybe my xbox 360 will see it. I hate doing all this, though, and once I get the money I'll be building a HDMI-out HTPC with Mythbuntu or XBMC so I can just play any format natively.
GOTSent, after conversion it leaves my .mp4's useless due to LOUD BEEPING
By Clifurd in forum Video ConversionReplies: 13Last Post: 16th Sep 2009, 05:01 -
Are there are other apps like gotsent? Looking to convert mkv to mp4
By AndyD in forum Video ConversionReplies: 42Last Post: 8th Sep 2009, 07:09 -
Fixing audio sync issues when using GOTSent to convert MKV to MP4
By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 07:56 -
GotSent MK4 to MP4 Image Size Problem
By CameraDamager in forum Video ConversionReplies: 3Last Post: 4th Jul 2008, 10:04 -
GotSent MKV to MP4
By tenzo_r in forum Video ConversionReplies: 14Last Post: 12th Mar 2008, 17:55
