Hi,
I'm using a computer with K-lite codec pack. I went to ffdshow folder and there is no executable, just the .ax and the .dll files.
There is a way to open ffdshow configuration screen without opening a movie which uses ffdshow and then going to the tray icon that opens automatically? In ohter words, I would like to know how to call the ffdshow config screen independently if I'm runing a video or not.
Thanks in advance![]()
I know I will get a nice executable for the config screen if I install later versions of ffdshow, but I'm just with this curiosity about how to call the ffdshow config screen without having an executable file.
I won't change the system state here because the computer is not mine and is working fine in this state.
Problems opening mkv to make screen caps with frameshots
By Wizard23 in forum ComputerReplies: 3Last Post: 15th Feb 2010, 16:16 -
ffdshow audio filter config
By THX-UltraII in forum Software PlayingReplies: 0Last Post: 17th Feb 2009, 03:12 -
Possible to get VirtualDub to open wmv/flv files without ffdshow?
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2008, 20:09 -
Image quality issues, specially in dark scenes..any ffdshow config to help?
By fgtan in forum Media Center PC / MediaCentersReplies: 3Last Post: 13th Nov 2008, 07:26 -
Opening Movie
By Gunna in forum Newbie / General discussionsReplies: 7Last Post: 13th Sep 2007, 17:08
